Forum topic by devann | posted 04-19-2011 01:33 AM | 7948 views | 1 time favorited | 7 replies | ![]() |
Topic tags/keywords: tip miter saw These are a couple pictures of my version of a jig to utilize the depth stop feature found on many sliding mitersaw. The work piece has to be held out away from the saw fence to take full advantage of the saw’s ability to make required depth cuts across the work piece. I made this out of some MDF and some cabinet trim. It’s held in place by screws through holes in the mitersaw fence. The second picture shows the bottom center of the blade cutting all the way across the work piece. At this point the saw blade has traveled as far back as possible at this depth setting. -- Darrell, making more sawdust than I know what to do with |
7 replies so far
#1 posted 04-19-2011 03:14 AM |
Darrell what are its advantages ? |
#2 posted 04-19-2011 03:35 AM |
With the work piece against the saw fence the center of the blade doesn’t travel to the saw fence. The depth of the cut will not be the same from one edge of the board to the other. I use this primarily when I take the saw to the jobsite. I use it to cut notches,tenons, etc… My portable tablesaw is a homemade job, so no grooves for a miter gauge. -- Darrell, making more sawdust than I know what to do with |
#3 posted 04-19-2011 05:19 AM |
My slider does have a depth stop, although I have never used it in this way -- E J ------- Always Keep a Firm Grip on Your Tool |
#4 posted 04-19-2011 06:21 AM |
E J, On mine the blade only passes the plane of the fence when it’s cutting full depth penetrating the ZCI. If I raise it to cut above the table the blade doesn’t cross that plane. That’s why I have to move the board out away from the fence closer to the center of the blade. -- Darrell, making more sawdust than I know what to do with |
#5 posted 04-19-2011 07:40 AM |
I have an older chop saw, but I hardly ever use it. Come to think of it, I haven’t used it at all for the last two years! LWL! Maybe I just need to add your jig. Thanx for sharing! -- LittlePAW - The sweetest sound in my shop, next to Mozart, is what a hand plane makes slicing a ribbon. |
#6 posted 04-19-2011 03:54 PM |
That’s handy and quick. -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
#7 posted 04-20-2011 02:37 AM |
I do the same thing for a quick cut Gene. But sometimes I spend more time looking for the right size block than it would have taken me to set up the jig. -- Darrell, making more sawdust than I know what to do with |
Forum | Topics |
Woodworking Skill Share
12027 |
Woodturning
2105 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4902 |
6691 |
28047 |
CNC Woodworking
211 |
Hand Tools
5404 |
Jigs & Fixtures
1417 |
Wood & Lumber
6232 |
1387 |
Focus on the Workspace
2153 |
1186 |
Woodworking Trade & Swap
4754 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8844 |
