smell burning wood through respirator?
Forum topic by jamsomito posted 02-28-2018 01:50 PM 460 views 0 times favorited 4 replies Add to Favorites Watch
View jamsomito's profile (online now)
jamsomito
313 posts in 631 days
02-28-2018 01:50 PM
Quick question here – can you smell burning wood through a P100 mask if it’s sealed properly?
I was ripping down some oak boards last night and my blade is in need of a cleaning. There was quite a bit of burning on the cuts. I could smell it slightly through my respirator which caught me off-guard. I am relatively new to woodworking, been using the respirator for about 6 months or so, and I’ve always been surprised by how much I can’t smell with it on. But I’ve never done this much cutting with this much burning before so I wasn’t sure. Just wondering if I should check my fit or if this is normal. Thanks.
EDIT: I should note my dust collection is non-existant. It is very high on the priority list though, already have a dust collector, but I only have 1×15A circuit in the shop so I can’t run it at the same time. Working on code and permit requirements for the electrical upgrade currently.
View Kazooman's profile
Kazooman
1243 posts in 2158 days
#1 posted 02-28-2018 02:40 PM
A P100 mask is a particle filter mask. It is not designed to remove vapors. You will be able to smell all kinds of things through it, even if it is sealing perfectly.
View jbay's profile
jbay
2896 posts in 1105 days
#2 posted 02-28-2018 03:01 PM
Quick question here – can you smell burning wood through a P100 mask if it s sealed properly?
But I ve never done this much cutting with this much burning before so I wasn t sure. Just wondering if I should check my fit or if this is normal. Thanks.
- jamsomito
You should double check the alignment of you saw, make sure your fence is parallel with the blade.
Then you should get your blade sharpened or buy a new one. Dull blades can cause accidents.
Be safe!
jamsomito
#3 posted 02-28-2018 03:22 PM
@Kazooman – thanks. I’m aware it’s just a particle filter. I was hoping that was the case, but wanted to be sure. First noticed that one time when I was in the shop and had to run in to use the bathroom – kept the mask on and the wife was making broccoli – that hit me upside the nostrils!
@jbay – thanks for the suggestion. I just did a project out of oak, albeit a lot smaller one, and there was no burning on that. I think this had to do with handling large boards (my possible error), and some binding as I cut (no riving knife). I’m pretty sure the blade just needs to be cleaned but next time I’m out there I’ll double check alignment. For what it’s worth, I pushed through about 100 linear feet yesterday, what I consider a lot anyway. Some pieces had burning most of the length and some had almost none.
View BoardButcherer's profile
BoardButcherer
144 posts in 300 days
#4 posted 02-28-2018 04:02 PM
The only perfect personal air filtration system is a full-body bubble-boy setup. No manufacturer has figured out how to make a mask that does a perfect seal around every possible facial structure.
A little bit of dust isn’t going to cripple you by the time you’re 40 either. I wouldn’t worry about things like catching a whiff of wood smoke every now and then. If you’re not coughing up a lung the mask is doing it’s job.
