How does the blade looks for this Sash fillister plane - HELP
Forum topic by mafe posted 04-19-2011 12:23 AM 7351 views 0 times favorited 22 replies Add to Favorites Watch
View mafe's profile
mafe
11634 posts in 2998 days
04-19-2011 12:23 AM
Topic tags/keywords: sash fillister plane
Hi LJ’s.
I bought a bunch of planes and among then were this wonderful old skeved sash fillister plane.
I have found out it was designed for making window frames, and even the use, but no details, And I have not been able to find any pictures of the blade.
http://www.sawmillcreek.org/showthread.php?158591-WTB-Sash-fillester-plane
Since it came without a blade I want to find or make one, so if some one have a plane like this or a book with a picture of the blade I will be really happy for some info.
As you can see the sole has a wedge that comes out, this confuse me!
How wide should the blade then be?
As the sole with or without the insert?
Hmmmm?
Best of my thoughts,
Mads
22 replies so far
View tdv's profile
tdv
1188 posts in 2979 days
#1 posted 04-19-2011 12:34 AM
Hi Mads do you think the plane may be a combination plane & there could be a selection of blade widths with different wedges to support the spacing between the sole of the plane & the depth stop? It also looks like a skewed blade.Looks like there should be a matching spacer wedge behind the blade too
Best
Trevor
-- God created wood that we may create. Trevor East Yorkshire UK
9983 posts in 3557 days
#2 posted 04-19-2011 12:39 AM
Check for glue residue in the slot on the base. My bet is that loose
part is what remains and there should be another one, but it’s missing.
A replaceable cheek perhaps, or a design feature put there to simplify
manufacturing.
The blade, a skew iron,, would be the width of the sole you have plus
the insert. I suspect hide glue held the inserts in place, but after
so long it just lets go.
View Dez's profile
Dez
1166 posts in 3987 days
#3 posted 04-19-2011 12:42 AM
The shape of the blade should match the profile of the body.???
-- Folly ever comes cloaked in opportunity!
View tdv's profile
tdv
#4 posted 04-19-2011 12:46 AM
I agree with Dez it looks as though it’s function is just rebating (rabbeting) sashes & not moulding with different infill widths to match different width blades
Trevor
View mafe's profile
mafe
#5 posted 04-19-2011 01:02 AM
View mvflaim's profile
mvflaim
189 posts in 3000 days
#6 posted 04-19-2011 01:44 AM
You have a sliding arm moving fillister plane. The plane blade is skewed and is as wide as the bottom. It’s only used with one blade. The idea behind them is that you can cut a rabbet behind the molding profile as it was customary to always work from the face.
View WayneC's profile
WayneC
13751 posts in 4007 days
#7 posted 04-19-2011 01:51 AM
I would recommend you send a PM to Lumberjock Philip Edwards. He makes moving fillister planes and I am sure he would be able to give you guidance or possibly make you one (he is a wooden plane maker) for a reasonable charge. He is in the UK.
Link to his plane.
http://www.phillyplanes.co.uk/index.php?option=com_content&view=article&id=12&Itemid=13
View bigike's profile
bigike
4053 posts in 3198 days
#8 posted 04-19-2011 01:52 AM
mads this is what I get http://www.adriatools.com/ece/ecespecialty.html#E48
View Chelios's profile
Chelios
568 posts in 2975 days
#9 posted 04-19-2011 02:00 AM
For a plow plane like this can be used with a variety of blades
see here http://www.planemaker.com/products.html
About 10 planes down on the list
View Dennisgrosen's profile (online now)
Dennisgrosen
10877 posts in 3024 days
#10 posted 04-19-2011 02:38 AM
No Chelios it ain´t a plough even though at first glimse it seems to
My gess is that its a skewed rabbetplane with two options for blades (lack of spurcutters )
the narrow blade is just a normal skewed blade like the one´s that is on shoulder/rabbets /plough planes
in construction with the tang in the mittle
and the wide blade is a combination between the shoulder/plough planeblade
and one from a side-escapements blade where the tang is set to one side only
I think that is what you are looking for …... I have looked thrugh my planebooks
and in none of them they seems to mention this type with two or more blades
to the same rabbetplane
I think its rare and unik plane you have found ….. and with your luck …..cheap too LOL
thank´s for sharing Mads
take care
Dennis
View bko's profile
bko
118 posts in 2926 days
#11 posted 04-19-2011 02:47 AM
Hi Mads,
This is a sash fillister. A normal fillister has a fence attached the bottom of the plane like the one WayneC shows above. A sash fillister has a fence that can “hop over” the work piece so the reference surface for the fence is not the one you are cutting into. By the way, an easy way to tell is that I have never seen a plow plane with a skew mouth and I have seen many sash fillisters and they all have skew mouths for a slicing cut.
The loose piece and the slot behind the blade are for “boxing” which is where a stronger wood, usually boxwood, is let into the plane to improve the wear resistance. You are missing a piece of boxing which is fairly typical. You can replace the missing piece with any tight-grained hardwood.
The blade for this plane is just like the blade for a wooden rabbit (rebate) plane, like so:
http://www.lie-nielsen.com/catalog.php?cat=548 See the 7/8 inch wide rabbit plane blade, but I will bet you need more like 1 1/4 inch. Put the blade in the plane and draw a line across the blade at the mouth, then grind back to that line with a square edge, then start putting the 30 degree bevel on the blade.
Looks like a fun project to restore it!
—Brian
View lwllms's profile
lwllms
555 posts in 3191 days
#12 posted 04-19-2011 03:01 AM
The iron for that plane looks like a regular molding plane iron but with a straight skewed cutting edge. Here’s a sash fillister I made a while ago:
The difference is the one I made is an off-the-bench sash fillister with a conical escapement and the one you’re looking at is an on-the-bench sash fillister with a regular side escapement. One throws shavings on the bench and thee other off. The main advantage of the off-the-bench style is that the skew works with the fence and tends to pull the fence tight to the work. The on-the-bench style have a skew that tends to push the fence away from the surface you’re registering against and you have to overcome this by forcing the fence into the work laterally.
The boxing is loose and you’ll need to repair it on this plane. I highly recommend you use Old Brown Glue for this. You can get it from Patrick Edwards who makes it, it’s an old formula liquid hide glue.
On edit: The iron is not shaped like a rabbet plane iron with a centered tang. It’s like a regular molding plane iron with the tang on the side. If you buy a Lie-Nielsen iron, size it by the tang width, not the width of the bit. Looking at the photos again, part of the boxing is missing, both arm wedges need to be replaced and the main wedge is missing. I really suggest you avoid trying to fix this plane. There are dealers who can supply an old one in good shape if you need one.
Chelios
#13 posted 04-19-2011 03:36 AM
Ahh Dennis , you are right. I see it now. I saw a plough plane at a show a while back and it sure reminded me of it. But I see what you mean now. BTW these are beautiful planes!
best
WayneC
#14 posted 04-19-2011 05:19 AM
I went and pulled my copy of Michael Dunbar’s Restoring, Tuning & using classic woodworking tools, pp 109-113. The curve in the blade is an illusion from the photo. the edges of the blade appear to be strait in the book.
Phil did post a fillister as a project on LJ. You can find it here. http://lumberjocks.com/projects/8097
View Sodabowski's profile
Sodabowski
2372 posts in 2742 days
#15 posted 04-19-2011 06:13 AM
Whatever it is, it sure looks old and used :)
-- Thomas - Pondering the inclusion of woodworking into physics and chemistry classes...
