Mechanical pencils
Forum topic by caboxmaker posted 02-27-2018 09:13 PM 1766 views 2 times favorited 50 replies Add to Favorites Watch
View caboxmaker's profile
caboxmaker
281 posts in 626 days
02-27-2018 09:13 PM
After reading the thread talking about pencil sharpeners I started thinking about mechanical pencils and the benefit that they never need to be sharpened. The point is always the point. Never sharper nor never dull. I’ve used mechanical pencils ever since I started woodworking. How many of you folks go mechanical over standard lead pencil? Here are my two goto pencils. If I need something sharper than .5 or .9 I use a knife to mark lines.
BTW, the wood in the background is NOT alder.
50 replies so far
View Charlie H.'s profile
Charlie H.
320 posts in 888 days
#1 posted 02-27-2018 09:20 PM
Kinda looks like alder though.
My mechanical pencils tend to evaporate…..no other plausible explanation for their total disappearance.
-- Regards, Charlie in Rowlett, TX --------I talk to myself, because sometimes I need expert advice.---------
View Loren's profile
10477 posts in 3886 days
#2 posted 02-27-2018 09:32 PM
It took me several years to go through a gross
of cheap mechanical pencils. I prefer them
too but I’ve been using regular pencils for
a few years now.
View Lazyman's profile
Lazyman
2707 posts in 1625 days
#3 posted 02-27-2018 09:38 PM
Definitely a mechanical guy. As you said…always sharp. I started using mechanical pencils in college because I hated having to carry a bunch of #2s to class and have used them ever since. I used to have 6 or 7 of them laying around the shop but over time they’ve been lost or broken so it is time for another box of 12 Pentel Cometz for $12 from Amazon. Last box lasted 9 years! Cheap and functional. I find that 5 mm is too flimsy for most woodworking and 7mm is only used when I cannot find the go-to 9mm that I normally keep in my shirt pocket.
View Jim Finn's profile
Jim Finn
2688 posts in 3160 days
#4 posted 02-27-2018 10:27 PM
I also keep a #9 in my shirt pocket. My 9MM is in my pants pocket. <grin>
-- No PHD just a DD214 Website> craftingcouple.com
caboxmaker
#5 posted 02-27-2018 10:34 PM
- Jim Finn
Grin?? So, you’ve got a pencil in your pants…
View WyattCo's profile
WyattCo
93 posts in 342 days
#6 posted 02-27-2018 10:42 PM
I was late to the party but finally starting doing the mechanical pencil thing a few years ago. It changed my woodworking for ever.
View Magnum's profile
Magnum
10932 posts in 3271 days
#7 posted 02-27-2018 11:40 PM
I studied as an Architect. I always used ”Staedtler Mars-Lumograph” Mechanical Drafting Pencils.
They are somewhat larger and stronger than your Standard Mechanical Pencils. (59 Years Later I’m still using the same Pencils and about a Million Leads.) ..lol..
They also supply EVERY Hardness of Lead that you would ever want, from “HB” (& Down, Soft) to about “6/8H” (Very Hard) in a plastic tube. 2H is ideal for General work.
You can change Leads in about 20 Seconds. You might have to go to a Drafting Supply Store to get them. It’s Worth It!
Thought I had a Pic on here but no luck. I’ll see if I can find one.
GOOGLE Found them for me. ...LOL…
Regards: Rick
-- Made In Ontario, CANADA
View fivecodys's profile
fivecodys
1272 posts in 1874 days
#8 posted 02-28-2018 12:13 AM
I use both depending on what task I am doing. Mechanical pencils seem to break their lead real easy when drawing a line but I like them for more precise marks.
I can’t ever seem to cut right to the line anyway so not sure why I even bother! :)
-- I always knew I would grow old, But I expected it to take longer!
Magnum
#9 posted 02-28-2018 12:32 AM
I can t ever seem to cut right to the line anyway so not sure why I even bother! :)
- fivecodys
” Mechanical pencils seem to break their lead real easy.” Have you tried a Larger (2 mm.) and a Harder Lead,
say 2H or up to 4H?
Rick
caboxmaker
#10 posted 02-28-2018 01:30 AM
Regards: Rick
- Rick
Rick, is this a tutorial on how to put lead in your pencil?
View oldnovice's profile
oldnovice
7380 posts in 3606 days
#11 posted 02-28-2018 02:05 AM
I use mechanical pencils exactly like the one shown above as I spent a few years in architectural design.
And, my wife always tells me to ”get the lead out!”
I also have one of these (not my photo)!
A.W. FABER-CASTELL LOCKTITE 9600 0.45×2.4MM FLAT DRAFTING PENCIL
Magnum
#12 posted 02-28-2018 02:34 AM
- caboxmaker
NAH! Staples didn’t have the proper Lead!
Magnum
#13 posted 02-28-2018 02:40 AM
- oldnovice
I REALLY Don’t want to ask this —————But————What is that WHITE Stuff coming out of the end where the LEAD should be? (Now I’n Gonna Be In Trouble!)
Now I see why “oldnovice” said ”I also have one of these (not my photo)!” and I Fell For It!
Not Little Ricky’s Picture!
View Dark_Lightning's profile
Dark_Lightning
3367 posts in 3347 days
#14 posted 02-28-2018 03:06 AM
I have a box of carpenter’s pencils that my youngest son bought me for xmas many years ago. Before that, I had bought the Staedtler’s 2mm mechanical pencil for gross marking. Depending on what I am cutting, I usually use a steel scale graduated in 1/64th inch increments. There, I mark the line with whatever, and cut at one edge of the mark. Easier to see by contrast than a score line with a marking knife…unless it is black pencil on ebony. ;)
I have big enough mitts that I have to use a .7 mm pencil at the least, because the .5 mm lead just breaks off.
-- Random Orbital Nailer
View Mario's profile
Mario
182 posts in 3634 days
#15 posted 02-28-2018 03:25 AM
I use a Pilot .5 only with Incra rules because it is what fits in them, for absolutely everything else I just canĀ“t let go a good quality wooden pencil, there is just something about them, I do run through one every week, have to keep it sharp as a needle…....maybe helps with deadline anxiety…pencils anybody?
showing 1 through 15 of 50 replies
