Tung oil food safe?
Forum topic by UncleStumpy posted 02-27-2018 08:59 PM 396 views 0 times favorited 5 replies Add to Favorites Watch
View UncleStumpy's profile
UncleStumpy
736 posts in 2429 days
02-27-2018 08:59 PM
I just read in the June 2017 issue of the Woodworkers Journal that Tung Oil can be used as a finish on kitchen utensils, cutting boards and bowls.
I doubt they would print false information, but I find this hard to believe.
I have been using stardard cutting block oil.
I was wondering if anyone has tried this method and the results.
Thank you in advance
-- "They don't want it perfect - they want it SPECIAL"
5 replies so far
View Woodknack's profile
Woodknack
12329 posts in 2496 days
#1 posted 02-27-2018 09:13 PM
Why do you find it hard to believe?
View JoshNZ's profile
JoshNZ
118 posts in 1185 days
#2 posted 02-27-2018 09:14 PM
I’ve used it on bowls and cutting boards for a long time without any problems. Pure tung oil from the tung nut is non-toxic, I guess there might be products called “tung oil” that contain tung oil and a drying agent which you might have to be a bit careful about. Look at the ingredients.
This is the label on the can I’ve been using.
View Richard Lee's profile
Richard Lee
145 posts in 891 days
#3 posted 02-27-2018 09:14 PM
If its “Pure” Tung Oil with nothing added its safe.
View crowie's profile
crowie
2567 posts in 2067 days
#4 posted 02-27-2018 09:58 PM
The Fine Woodworker from way back says it’s okay as long as it’s PURE…
http://www.finewoodworking.com/2006/08/01/food-safe-finishes
-- Lifes good, Enjoy each new day...... Cheers from "On Top DownUnder" Crowie
UncleStumpy
#5 posted 02-27-2018 10:54 PM
Wood knack, because I have never worked with it and always had in my mind an obvious false impression of what the stuff is.
I probably should have gone to the store and read the can!
Thanks to the rest of you guys.
Crowie, good to hear from you again mate
