Notching Bamboo Long-Wise
Forum topic by Marcel T posted 251 days ago 154 views 0 times favorited 9 replies Add to Favorites
View Marcel T's profile
Marcel T
146 posts in 254 days
251 days ago
Have any of you ever notched (Cut bamboo through one wall) long-wise on a table saw? (Or at all?) Even if you haven’t, what would you imagine would be a good idea? (Like a longer fence)
Thanks,
Marcel
View mrtrim's profile
mrtrim
1548 posts in 408 days
251 days ago
i do it a lot ! did a bunch last week
mrtrim
251 days ago
mrtrim
251 days ago
i screw the bamboo to a board on its straightest side and run the board against the fence . in the photo , the faceframes are cut in half down the middle . the center section on top is notched out 3/4 in and slid on over the arched maple valence . and the one below is notched and slid on to the front of the shelf hope it helps !
http://lumberjocks.com/projects/3855
Marcel T
251 days ago
Thanks Mr. Trim!
mrtrim
251 days ago
my pleasure , good luck ! and i would not stand directly behind the bamboo during this process
Marcel T
251 days ago
Do you experience a lot of kickback from a operation like this?
mrtrim
251 days ago
no not really but i think theres a possibility so i do it very carefully , the noise it makes is a little scary at first .
when im cutting a notch i usually cut one slice on my mark and then move the fence to the 3/4 mark slice again then take out the middle one slice at a time during this process the center part can come flying out towards you thats why i stand to the side
View tomd's profile
tomd
115 posts in 298 days
246 days ago
I used to make fly rods for fishing out of bamboo. The quality that made it so good for fishing rods is the fact that bamboo splits very easy and very straight. If you wish to split it in two down the middle just take a fore,(a blunt large knife) and hammer and tap it down through the middle , the bamboo will split easly to the nodes then you must tap it through the node and it will split easly to the next node, and you continue on from node to node. You will find that you will beable to control it very well. If you only need to take out a notch use a carpet or hook nose knife (a dull one ) so you only go through the wall, tap it down and redo it the width you desire. When doing fishing rods we normally would split it into 1/4” strips. If you get any twist or bend bamboo is very plyable if heated. Use a propane torch like you use for plumbing, heat it where the bend or twist is and the hold it straight till it cools and it will remain in that shape.
-- Tom D
Marcel T
246 days ago
I’ll try that Tom. Thanks!
Bookmark And Share This Page
