negative rake scraper
« back to Woodturning forum
Forum topic by Karda posted 02-27-2018 07:19 AM 435 views 0 times favorited 3 replies Add to Favorites Watch
View Karda's profile
Karda
1383 posts in 793 days
02-27-2018 07:19 AM
Hi, I want to make a couple negative rake scrapers, but not sure how, Is 1/4 inch thick enough for a 1 inch scraper or should it be thicker. thanks Mike
3 replies so far
View gwilki's profile
gwilki
239 posts in 1712 days
#1 posted 02-27-2018 02:45 PM
I’ve ground a couple of my scrapers into negative rake. Neither of them is greater than 1/4” thick and they work well.
FWIW, the conventional wisdom seems to be that the included angle of the two bevels should be less than 90°. You will find many opinions on what each bevel should be. I keep mine at the same angle as it makes sharpening easier.
-- Grant Wilkinson, Ottawa ON
View LeeMills's profile
LeeMills
629 posts in 1540 days
#2 posted 02-27-2018 06:36 PM
It should work well for a negative rake. Per Batty (and others) the handle behind the tool rest for a standard scraper is 7 X the overhand. For a negative rake it drops to 3 X the overhang because there is so much less force on it. It also depends on how far over the tool rest you plan to work.
That said, I think thicker is always betta.
Karda
#3 posted 02-27-2018 11:44 PM
ok thanks
