What are the use cases of an X-Carve CNC Router?
« back to CNC Woodworking forum
Forum topic by ppg677 posted 02-27-2018 05:58 AM 301 views 0 times favorited 5 replies Add to Favorites Watch
View ppg677's profile
161 posts in 792 days
02-27-2018 05:58 AM
I have the opportunity to buy a used 750mm x-carve for pretty cheap.
Besides doing signs and such, what are the use cases?
My woodworking is mostly furniture.
5 replies so far
View oldnovice's profile
6692 posts in 3303 days
#1 posted 03-05-2018 08:01 PM
I am a hobbyist and a CNC can do a lot more than just make signs!
  1. Make templates for hand held routers for higher piece work throughput!
  2. Make repetitive pieces with very high accuracy.
  3. You can cut wood, plastic, and on some even cut metal,
  4. You can 3D relief carve in different materials.
  5. A CNC can be cutting while you are doing something else.
  6. I am probably missing somethings …..
View Ocelot's profile
1899 posts in 2574 days
#2 posted 03-05-2018 08:59 PM
I’m not familiar with the particular product, but I know some people use CNC for carving seats for chairs. If you are making a set of chairs just alike, it makes it easy.
#3 posted 03-06-2018 12:00 AM
For examples of what a CNC can do check out some videos on YouTube “woodworking cnc” and/or “CNC” for other than woodworking as there are enough to keep one occupied for hours.
RogerWebb who does a lot of varied projects!
Technology Solutions for some delicate industrial carving.
Mick Martin
And dozens of others!
View Mike_D_S's profile
443 posts in 2150 days
#4 posted 03-06-2018 10:30 AM
I have a significantly larger machine than the Xcarve, but besides the normal signs, 3D carving, etching, etc hobby type stuff I use it a lot as an assistant for my woodworking.
Primary uses:
1. Templating: Whether it’s cloud lifts, waterfall details or any other thing that requires a router template, I pretty much always make the templates on the CNC. I find it’s a lot easier to just draw the template and throw on a piece of MDF and come back 15 minutes later for the jig than penciling the design, cutting the jig and then sanding to perfection.
2. Shelf pin holes: The Xcarve might be a bit small for this, but I can lay a cabinet side on mine, clamp it and hit go and come back 5 minutes later to perfectly positioned shelf pin holes.
3. Mortising: I’m doing more of this, but I’ve started using it to make router mortises. I used to make a template and then cut the mortises. Now I just draw a rectangle, add half circles then calculate the tool path and get to cutting.
The one thing I’ll say is that CNC is half computer skills, half mechanical aptitude and half woodworking. :)
So there is a learning curve to it and the better your ability to draw the part you want the easier it’ll be.
-- No honey, that's not new, I've had that forever......
4173 posts in 2345 days
#5 posted 03-06-2018 03:49 PM
If you can get it cheap as you said do so. Like any other tool it will expand your abilities and as you learn to use it more you will find more applications for it. You hear this comment alot about having a lathe. I originally bought my lathe to make pens and such. These days I rarely make these items but have two lathes and the possibilities are endless..
