Bandsaw hand-tool replacement?
Forum topic by ajw2250 posted 04-18-2011 04:48 PM 15150 views 0 times favorited 11 replies Add to Favorites Watch
View ajw2250's profile
ajw2250
9 posts in 2621 days
04-18-2011 04:48 PM
Hi everyone,
New to Lumberjocks, not new to woodworking!
My current obsession is having a hand-tool only woodshop, inspired by Tom Fidgen.
My question – what is the best hand-tool to replace the bandsaw? Two categories: resawing/ripping and cutting curves.
-- Anthony in Ottawa, ajwilson.com
11 replies so far
View saddletramp's profile
saddletramp
1180 posts in 2663 days
#1 posted 04-18-2011 05:28 PM
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3140 days
#2 posted 04-18-2011 05:51 PM
for resawing /riping you can both use a handsaw and a frame saw
for the curved work a framesaw with a thin blade , fretsaw big and small is the right choice
dependig of sice and thickness of materiel
good luck onto the journey of the Galoot lane :-)
welcome to L J enjoy and have fun
take care
Dennis
View Bertha's profile
Bertha
13529 posts in 2718 days
#3 posted 04-18-2011 06:03 PM
Treadle scrolls are one of the coolest things in existence. I’m a handtool heavy guy myself but I don’t seem to do a lot of curved work. Resawing by hand is an impressive goal. A massive ripsaw and a nice sawbench might be handy. A bowsaw and coping saw should get you around the curves. Good luck!
View Loren's profile
10476 posts in 3673 days
#4 posted 04-18-2011 07:17 PM
You can saw veneers with a bowsaw. You can saw dovetails,
tenons, and rip fast with a rip blade with it.
If I could have only one saw, it would be a bowsaw… but I’d
resent not having a ryoba as well.
If you’re into making your own you-powered machinery, look up
walking beam saw plans.
View David Kirtley's profile
David Kirtley
1286 posts in 3023 days
#5 posted 04-19-2011 02:51 AM
I only occasionally fire up my bandsaw when I have lots of cutting or I am cutting metal. Here is what I have for my main saws:
A couple frame saws. One set up rip, one crosscut. You can also get narrower blades for curves.
(Pic is from Traditional Woodworker—Highland Woodworking sells also but I like the ECE better than the Ulmia Adria Tools also sells the ECE)
I have a big one with a rip blade and a smaller one with crosscut.
(The rest of these are from Toolsforworkingwood.com)
A bowsaw
A coping saw
A fret saw
But, I’m not giving up my bandsaw. :)
View rance's profile
rance
4258 posts in 3185 days
#6 posted 04-19-2011 03:16 AM
A BIGGER bandsaw! :) Or maybe a Jointmaker Pro ( http://www.bridgecitytools.com/blog/tag/jointmaker-pro/ ).
ajw2250
#7 posted 04-21-2011 03:37 AM
David Kirtley – exactly what I was looking for!
How did you prepare the blades on your big ECE frame saws. I have used one and the cut always drifted to the right, regardless I what I tried – any advice?
Thanks…
Dennisgrosen
#8 posted 04-21-2011 10:13 AM
most highly the way you hold the saw when you saw
but it cuold be a few teeth on the right side that have a little bigger set than
the others …. that wuold get any saw to drift
Dennis
View bubinga's profile
bubinga
861 posts in 2693 days
#9 posted 04-21-2011 10:40 AM
This guy here builds furniture with hand tools only, he has a lot of great videos, some showing how to make the tools, check it out
Welcome to the New Logan Cabinet Shoppe Blog
http://www.logancabinetshoppe.com/blog/
-- E J ------- Always Keep a Firm Grip on Your Tool
ajw2250
#10 posted 04-22-2011 02:25 AM
Thanks Bubinga!
David Kirtley
#11 posted 04-24-2011 03:58 AM
Ajwilson:
The only thing I did to my saws is get rid of the metal screw tightener. I put dyneema line on it with a toggle. If you are not familiar with it, dyneema is just an ultra low stretch line.
Just tension the blade and make sure it does not have any twist and you are good to go. You do have to make sure that you don’t try to push it too hard or it can drift (for the same reason a bandsaw does if you feed the stock too fast). Let the teeth do the cutting.
Also, you don’t want the blade to be in line with the frame, you turn it a bit to one side or the other depending on what you are doing and what is comfortable . Otherwise, you can’t see where you are sawing.
