What is the best tool to achieve a flat surface?
Forum topic by becikeja posted 04-18-2011 12:44 AM 7529 views 0 times favorited 10 replies Add to Favorites Watch
View becikeja's profile
becikeja
962 posts in 3049 days
04-18-2011 12:44 AM
I need to create a perfectly flat surface. I am using a router and attempting to engrave in wood 0.05” deep. What I have noticed is that my block sanding efforts, unfortunately do not always yield a perfectly flat surface. I’m considering a sand-flee, a drum sander, or maybe a planar to get the flat surface need, or is there something else I should be using. Your advice is most appreciated.
10 replies so far
View knotscott's profile
knotscott
8174 posts in 3611 days
#1 posted 04-18-2011 12:53 AM
A planer smooths, thins, and duplicates the opposite face….it does not inherently flatten boards without the help of a planer sled, but a jointer definitely will!
View cabs4less's profile
cabs4less
235 posts in 2998 days
#2 posted 04-18-2011 01:32 AM
jointer and i have heard bad things bout the sand flee enough to scare me away from buying
-- As Best I Can
117417 posts in 3813 days
#3 posted 04-18-2011 01:35 AM
another vote for a jointer, The wider the better
View popmandude's profile
popmandude
109 posts in 3256 days
#4 posted 04-18-2011 02:04 AM
Jointer.
Photobucket #7, the one on the right
View Viktor's profile
Viktor
466 posts in 3654 days
#5 posted 04-18-2011 02:29 AM
It will depend on the size of the surface. How big is it?
View Loren's profile
10477 posts in 3883 days
#6 posted 04-18-2011 02:44 AM
A “sanding board” is very useful, and very cheap to make, for
making wood surfaces very, very flat.
View Yupa4242's profile
Yupa4242
116 posts in 2836 days
#7 posted 04-18-2011 05:13 AM
I cant remember which episode of the Wood Whisperer but he made a router jig for flattening out very large pieces.
-- "If the Universe is Infinite, Then all dreams are real."
becikeja
#8 posted 04-22-2011 03:21 AM
I usually start with a 6 or 8 inch wide board, so a planer would work. The joiner idea is one I keep coming back to, but I just don’t understand how they work. It seems to me that running it through the joiner would take the same amount of surface off of the board for the entire length, and it still wouldn’t flat, just thinner. I am obviously missing something.
#9 posted 04-22-2011 03:35 AM
Works the same as a handplane. A jointer takes off the high spots. Take them
all off and it will, in a perfect world, cut your board uniformly flat.
In our imperfect world however, operating a jointer and milling extremely
flat and straight boards requires considerable operator skill. It’s much
easier if the boards are 24” or less. Accurately flattening 8 foot boards
on a jointer requires skill and insight with the tool.
View ryno's profile
ryno
106 posts in 3899 days
#10 posted 04-22-2011 04:21 AM
Becikeja, with the jointer, the infeed side of the jointer is slightly lower than the outfeed side. When you feed the board into the blade it takes a smidge off. When you get enough of the workpiece past the blade you keep your pressure on the outfeed side of jointer just past the blades. This method is what makes a perfect flat board.
-- It is better to keep your mouth shut and appear stupid than to open it and remove all doubt.
