finish on copper ferrule ?
« back to Woodturning forum
Forum topic by Abter posted 02-26-2018 08:32 PM 781 views 0 times favorited 13 replies Add to Favorites Watch
View Abter's profile
Abter
69 posts in 741 days
02-26-2018 08:32 PM
I am putting copper ferrule’s on handles I’m making for carbide tools. I can’t find a good discussion on whether I need to (or should…or could) put a finish on the polished copper ferrules. Do I leave the copper naked? use a varnish or shellac? a wax-and-varnish friction finish?
-- "Many men fish all their lives without ever realizing that it is not the fish they are after." {often mis-quoted as by H.D. Thoreau}
13 replies so far
View Loren's profile
10477 posts in 3762 days
#1 posted 02-26-2018 08:36 PM
Lacquer is used on brass instruments. Prevents
oxidation.
View TheFridge's profile
TheFridge
10081 posts in 1600 days
#2 posted 02-26-2018 08:42 PM
Probably by far the best choice. I use wax on brass but it still ages slowly.
View Notw's profile
Notw
662 posts in 1867 days
#3 posted 02-26-2018 09:29 PM
i’ve used copper on turned ornaments before and used sprayed lacquer and they seem to stay nice and shiny
View MalcolmLaurel's profile
MalcolmLaurel
298 posts in 1737 days
#4 posted 02-27-2018 01:11 AM
I usually scotchbrite copper parts for a brushed finish so I’ll often leave them bare and figure on scotchbrite again if they tarnish. But I’ve had good results with shellac, too.
-- Malcolm Laurel - http://MalcolmLaurel.com
View Woodknack's profile
Woodknack
12329 posts in 2494 days
#5 posted 02-27-2018 07:07 AM
My issue with copper ferrules has been that the copper tends to be splotchy or less shiny even if I apply a thin coat with a paper towel. Maybe I need to apply it thicker so I can buff it out. Next time I might try super glue. With no finish the copper eventually oxidizes.
View gwilki's profile
gwilki
216 posts in 1588 days
#6 posted 02-27-2018 04:55 PM
I leave the copper ferules on my tools “naked”. It’s a tool, not a piece of art. Over time, they change colour, but I really don’t mind it at all.
-- Grant Wilkinson, Ottawa ON
View LittleShaver's profile
LittleShaver
358 posts in 733 days
#7 posted 02-27-2018 05:58 PM
+1 on naked for tools.
-- Sawdust Maker
View Nubsnstubs's profile
Nubsnstubs
1357 posts in 1844 days
#8 posted 02-27-2018 06:52 PM
I leave the copper ferules on my tools “naked”. It s a tool, not a piece of art. Over time, they change colour, but I really don t mind it at all.
- gwilki
Yep, totally agree. Tools must have that used look to be of any value…......... Jerry (in Tucson)
TheFridge
#9 posted 02-27-2018 07:23 PM
I like naked
View Lazyman's profile
Lazyman
2383 posts in 1501 days
#10 posted 02-27-2018 08:57 PM
Another option is to add a patina to it. You can simply heat the ferrule with a torch to sort of pre-oxidize it, which gives it a nice aged look. You can even use borax or even just plain table salt to give it an interesting mottled red color after heating with the torch. Another approach that I saw in Shop Notes magazine was to put peanut oil or even boil linseed oil (no varnish) or tung oil and then heat it with a torch to give it a nice darkened color. Different types of oil will give you slightly colors.
Nothing wrong with a tool, especially one you make yourself, looking like a piece art.
Edit: You can see an example of a copper ferrule for an awl that I got an accidental patina on here:
http://lumberjocks.com/projects/271778
I actually coated it with Tried and True varnish oil along with the rest of the handle but the patina was caused by repeatedly annealing the copper pipe with a torch as I was making it square. You’ll have to ask Rick M (Woodnack) how it held up because it was part of a LJ tools swap.
View rodneywt1180b's profile
rodneywt1180b
174 posts in 500 days
#11 posted 03-11-2018 08:49 PM
I tend to leave it naked and let it age on it’s own. Waxing it will slow the oxidation down. The problem with finishes is they will eventually crack, chip, get scratched, etc, then the copper underneath will oxidize anyway, usually in an unsightly way.
Rodney
-- Rodney, Centralia, WA, USA www.etsy.com/shop/ASturdyStick
Nubsnstubs
#12 posted 03-12-2018 03:40 PM
I was in the Army back in the day, and we had brass belt buckles. As most might know, the military doesn’t like rust nor oxidation on things. So, the belt buckles were polished to a mirror finish using Brasso, and rust was removed with elbow grease and oil that was supplied, or the rust was removed and the part that had rust was painted. So, if you want, polish your ferrel with Brasso, or paint it, and when the copper starts showing any type of discoloration, polish it again, or remove the existing finish, and refinish it. After awhile, you’ll say, “Screw that crap”, and let nature take it’s course. ............ Jerry (in Tucson)
View Kelly's profile
Kelly
2071 posts in 3058 days
#13 posted 03-25-2018 04:28 AM
I use lacquer on my spindle turnings I copper plate.
