Biscuit Joinery
« back to Joinery forum
Forum topic by Floyd Hall posted 02-26-2018 08:16 PM 1114 views 1 time favorited 32 replies Add to Favorites Watch
View Floyd Hall's profile
Floyd Hall
111 posts in 293 days
02-26-2018 08:16 PM
Topic tags/keywords: jig router biscuit joiner
Hi folks,
Trying to decide if I need to go buy a biscuit joiner or if I should just go ahead and try it with a router. I don’t anticipate using a biscuit joiner much, but I do have a job it would be good for right now. Any jigs out there? Any thoughts?
Floyd
32 replies so far
View jerryminer's profile
jerryminer
926 posts in 1463 days
#1 posted 02-26-2018 08:22 PM
If you already have a router, a 4mm (or 5/32”) slot cutter will make a biscuit slot. No jig necessary, but you could make a jig to limit the length of the slot if you wish.
4997 posts in 2515 days
#2 posted 02-26-2018 08:23 PM
I’d also go with the slot cutter.
View Loren's profile
10476 posts in 3670 days
#3 posted 02-26-2018 08:27 PM
The joiners are more versatile than a router,
especially the ones with tilting fences. If you
are meticulous in your approach to using them
precise results can be had.
You can get round Lamello biscuits that go
deeper than a standard biscuit. I’ve used
them on frames.
Cheaper plate joiners may be frustrating to use.
The weak link in them tends to be the fence.
The pricier ones have more reliable fences in
general. I had a Freud one with a fence that
wouldn’t hold its settings.
Floyd Hall
#4 posted 02-26-2018 08:45 PM
Yeah, I got one already, that’s why I was thinking about it. Just not sure how to steady the router.
Floyd
I d also go with the slot cutter.
- Fred Hargis
Floyd Hall
#5 posted 02-26-2018 08:48 PM
A Makita just came up on CL, but he wants a little too much for it. The reviews suggest a DeWalt or a Porter Cable, but I’ve become frustrated with my Porter Cable tools over time. And slippage seems to be the main issue.
Anyway, I was thinking about just trying the router for now and maybe look at a Festool when I’ve died and gone to heaven.
Floyd
deeper than a standard biscuit. I ve used
them on frames.
wouldn t hold its settings.
- Loren
View LesB's profile
LesB
1748 posts in 3465 days
#6 posted 02-26-2018 11:09 PM
Before the biscuit cutters became available I used a slot cutter on my router and cut my own biscuits. In some cases I cut the slot almost the complete length of the boards I was joining and either inserted several biscuit size pieces at points along the slot or used a full length piece of plywood or masonite that filled the entire slot. You could also make slots using your table saw.
Be aware that biscuits do not add much strength to the joint but primarily keep the boards aligned, particularly during the glue up process.
-- Les B, Oregon
Floyd Hall
#7 posted 02-26-2018 11:22 PM
Yeah I was thinking about using 1/4i plywood splines and cutting the slots with a slot cutter on a router.
What I’ doing is building a work table with 1 1/4i. So I was thinking about two splines. I would like to attach 6/4 hickory aprons around the table top. I do need it to be pretty sturdy.
Floyd
- LesB
View Rayne's profile
Rayne
910 posts in 1562 days
#8 posted 02-27-2018 01:16 AM
If you want a relatively cheap alternative, Harbor Freight’s biscuit joiner isn’t too bad at all. Most of the plastic parts that had complaints in the past were fixed and replaced with cast aluminum. There is some play, but very manageable. Just need to buy a better cutter. I bought Freud’s and it works like a charm for me. My 2 cents for a once-in-a-while tool.
woodbutcherbynight
4818 posts in 2431 days
#9 posted 02-27-2018 04:36 AM
Depends on your approach. A dedicated tool like a biscuit joiner is set up and with an adjustment for depth and setting the fence ready to go. Using your router if you have only one means changing the bit and doing the other set up process. Doing splines or half splines get the job done. All of these methods get the job done. Each has pros and cons so it boils down to which would you rather have.
I have a biscuit joiner, and no I do not use it all that regularly but when needed it is set up and ready to go. Like many others I have several routers, some set up for certain work and also have a router table.
View CaptainKlutz's profile
CaptainKlutz
276 posts in 1516 days
#10 posted 02-27-2018 05:45 AM
Hmm..
Biscuit construction is like any other type of joinery? Each one has pro/con; and a loyal fan base.
Some prefer splines or dowels over biscuits?
If you have never used biscuit construction on a project before, suggest you try using router with 5/32 slot cutter and bearing. Unless you snag a porter or dewalt biscuit joiner from Craigslist cheap (which happens often), router method is cheapest method to determine if you need/want/like using biscuits.
You mention joining 5/4 top to 6/4 apron?
For workbench application were strength is goal, I would use mortise & tenon, loose tenon, or spine to attach the apron. Biscuits are great for 4/4 lumber, but if you are using thick lumber then you have room for a thicker tenon/spline.
Floyd Hall
#11 posted 02-27-2018 06:17 AM
- CaptainKlutz
I was thinking about two 1/4i plywood splines or maybe one 1/4 spline and a second series of biscuits. I could use a cross-cut sled and cut both biscuit slots at the same time so they match up.
Floyd
View John_H's profile
John_H
175 posts in 1728 days
#12 posted 02-28-2018 05:46 AM
If you haven’t seen this Lamello Video it is worth watching
https://youtu.be/IecEPB64TgU
View pintodeluxe's profile
pintodeluxe
5701 posts in 2835 days
#13 posted 02-28-2018 05:54 AM
Get the biscuit joiner. I use a few biscuits on most projects, and it’s super handy.
It’s no substitute for mortise and tenon joinery, but there are many useful applications.
#14 posted 02-28-2018 06:09 AM
In the 80s and 90s the woodworking magazines
went a little hog wild with designs using biscuit
joints in place of mortise and tenon. Some were
better designs than others but by today’s standards
there was some dubious stuff out there.
There’s a mistaken idea going around that biscuits
provide no strength. They provide no relevant
strength
in edge to edge grain gluing of solid
wood when making things like panels and table
tops. Those joints are stronger than the wood
anyway when using modern glues. Biscuits can
provide plenty of strength in frame joints, carcase
joints and miter joints, basically most situations
involving plywood or end grain.
View jimintx's profile
jimintx
799 posts in 1606 days
#15 posted 02-28-2018 06:24 AM
Loren has made the point above. Biscuits do improve joint strength in many cases, as he explained.
I still use my very old Ryobi biscuit jointer for quite a few projects. I’m very happy to have it and use it. Maybe I should consider and compare it to a current model like a Dewalt, or similar.
-- Jim, Houston, TX
showing 1 through 15 of 32 replies
