| Forum topic by Beginningwoodworker | posted 766 days ago | 1779 views | 0 times favorited | 15 replies | ![]() |
766 days ago |
I am wondering do staples hold better in cabinet backs? My brad nailer dont hold 1/4’’ plywood to good. -- CJIII Future cabinetmaker |
15 replies so far
#1 posted 766 days ago |
Crown staples hold very well. Get real short ones – like 5/8” You can “toenail” brads at an angle too. They hold a bit |
#2 posted 766 days ago |
CJ, Ditto what Loren said. The length of the staples will depend on the thickness of the cabinet back but for 1/4”, Loren is right on. Lew -- Lew- Time traveler. Purveyor of the world's finest custom rolling pins! |
#3 posted 766 days ago |
I use 1/4’’ plywood for cabinet backs, could I hand nail the cabinet backs? -- CJIII Future cabinetmaker |
#4 posted 766 days ago |
Sure. You might try the ring-shank paneling nails if you’re concerned about |
#5 posted 766 days ago |
i dado my backs into a grove -- david - only thru kindness can this world be whole . If we don't succeed we run the risk of failure. Dan Quayle |
#6 posted 766 days ago |
This is what I use, from Harbor freight, 30 bucks , on kitchen cabinets -- E J ------- Always Keep a Firm Grip on Your Tool |
#7 posted 766 days ago |
I use a rabbet joint for the 1/4’’ back to sit in. I might try cut brad nails. They have more holding power. -- CJIII Future cabinetmaker |
#8 posted 766 days ago |
Wide crown staple 5/8” long, bead of glue. -- Sam Hamory - The project is never finished until its "finished"! |
#9 posted 766 days ago |
Yes I forgot the glue -- E J ------- Always Keep a Firm Grip on Your Tool |
#10 posted 766 days ago |
Glue and 5/8 staple for us. We also use David’s technique at times. -- Jerry Nettrour, San Antonio, www.topqualitycabinets.net |
#11 posted 766 days ago |
The crown stapler and glue will do you. If you are in a pinch and only have an 18 gauge brad gun, use 1/2” or 5/8” at most, be sure to turn the pressure down so the brad won’t blow through the luan (or whatever), glue and shoot. We use this method to attach the finished toe kick veneer on cabinets where we can not use the crown staples. It works just fine as long as the pressure is set correctly. Also, I personally cannot stand crown staples for trimming door casing (like nearly all the factories do). I order interior doors without trim (and often solid jamb) so we can get it right and leave it smooth for the painter or finisher. -- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia |
#12 posted 766 days ago |
Same has David & Jerry. Having a little space between the back of the cabinet and the wall allows for a cleat to be fastened to the wall. This makes for an easier installation to get everything hanging straight. The staples will hold better than the brads because many times you’re penetrating into two grains of the wood instead of one. -- Darrell, making more sawdust than I know what to do with |
#13 posted 766 days ago |
yes in a rabbet -- jack -- ...measure once, curse twice! |
#14 posted 765 days ago |
Patron and I use the same system, dadoing for the back. I have seen too many installations that have failed by rabbeting the sides for the back. The back stays attached to the wall and the cabinet is on the floor! -- Don, Pittsburgh |
#15 posted 765 days ago |
Wall cabinets I put a 4” wide horizontal at the top back of the cabinet, The back I usually make a 1/2” deep rabbet on the sides for bottom |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1534 |
3550 |
15787 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
