Jointer Blade Size Question
Forum topic by Pthomas180 posted 02-26-2018 04:41 PM 279 views 0 times favorited 4 replies Add to Favorites Watch
View Pthomas180's profile
Pthomas180
10 posts in 211 days
02-26-2018 04:41 PM
Hello. I have a jointer that takes 6” x 1” x 1/8” blades. I am looking at some 6” x 7/8” x 1/8” blades. I assume the 7/8” height vs. 1” is not going to make a difference and will fit fine. I seem to have quite a bit of room when I’m placing blades in the cutter head. I wanted to check before ordering though. I have a G1182 jointer and Grizzly could not give me a yes or no answering without “being in front of the machine.” Thanks.
View MrUnix's profile
MrUnix
6884 posts in 2315 days
#1 posted 02-26-2018 04:53 PM
I don’t think that 1/8” will make much of a difference other than not being able to sharpen them as much, but since you are ordering new knives, why not just get the right size?
Pthomas180
#2 posted 02-26-2018 04:57 PM
Pretty much the price. I’m looking at some Freud blades that are only $29. Any suggestions for alternate brands welcome though. I appreciate the response.
MrUnix
#3 posted 02-26-2018 06:27 PM
Those Freud C360’s should be fine. The C370’s are the correct size, but only ship in sets of two. Here are a few other options though:
6 x 1 x 1/8 Jointer / Planer Knives, Grizzly – $24.90 at amazon
Set of 3 HSS Blades for Grizzly 6'' Jointer, G1182 – $23.75 at mywoodcutters.com
I think Powertec also has a set, but can’t find them at the moment.
You can also go a bit longer, and use the 6-1/8” kinves, so your selection opens up even more.
Pthomas180
#4 posted 02-26-2018 06:56 PM
Thanks. Called Grizzly again and got a different person. Unless really off, the height only affects how many times you can sharpen. So they agree with you- the Freud blades referenced above will work. Thanks again.
