Sawstop Injury - you should check this
Forum topic by rwe2156 posted 02-26-2018 01:44 PM 2305 views 0 times favorited 32 replies Add to Favorites Watch
View rwe2156's profile
rwe2156
3069 posts in 1600 days
02-26-2018 01:44 PM
I didn’t know this could happen.
If I owned a SS I would be a bit concerned.
32 replies so far
View Tennessee's profile
Tennessee
2880 posts in 2634 days
#1 posted 02-26-2018 01:56 PM
Yeah, the hot dog shows I have seen show the dog not even getting a slice in it, even though they put the side of the dog against the blade.
My best guess and speculation is that possibly the tip of his thumb had a nice callous on it, and did not have the moisture in the skin that the unit needs to see, (like a touch screen), to make it fire in time. But that is just a guess.
View YesHaveSome's profile
YesHaveSome
115 posts in 378 days
#2 posted 02-26-2018 02:51 PM
He was using a blade SawStop says not to use because it can’t be stopped as quickly.
-- But where does the meat go?
View johnstoneb's profile
johnstoneb
3000 posts in 2292 days
#3 posted 02-26-2018 02:55 PM
The injury is minor compared to what it could have been if mechanism hadn’t fired.
-- Bruce, Boise, ID
View MinnesotaSteve's profile
MinnesotaSteve
54 posts in 1011 days
#4 posted 02-26-2018 03:40 PM
I believe he touched the blade with his fingernail, which is non-conductive and didn’t register until it cut into it.
Something to be mindful of, but at least he didn’t lose his finger.
View JollyGreen67's profile
JollyGreen67
1676 posts in 2882 days
#5 posted 02-26-2018 04:17 PM
interesting – BAM ?
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected ! RIP 09/08/2018
YesHaveSome
#6 posted 02-26-2018 04:23 PM
I believe he touched the blade with his fingernail, which is non-conductive and didn t register until it cut into it.
Something to be mindful of, but at least he didn t lose his finger.
- MinnesotaSteve
Even if it cut his fingernail first it should have stopped when it hit the skin. Again though, he was using a blade that SawStop says not to use. That blade was actually bad from two perspectives 1) it had shoulders 2) it was painted. SawStop says to only use blades without shoulders and that are bare metal.
View bbasiaga's profile
bbasiaga
1240 posts in 2114 days
#7 posted 02-26-2018 05:03 PM
I saw this video. I could not bring myself to watch the injury part itself. That stuff grosses me out.
I believe from his description that his thumb was saved from amputation. Sounds like there was more tissue damage than usual, owing perhaps to the painted blade and the slower to stop design features of the teeth, but a save none the less.
I did some math once in one of those threads on how deep a cut could be depending on how fast youjr hand was moving and given their 5ms stop time. It was pretty small at fast feed rates. I want to say in the 32nds of an inch range. BUT, his hand was not feeding the board. He was reaching forward, and your hand in that case would be moving MUCH faster than one smoothly feeding a board through. So that would deepen the cut. Add in the slower response tikme of the pai need blade and worse still. .
So someone needs to volunteer to thbrow a hot dog at top speed in to their sawstop and see what it looks like. My tool budget is blown for the month so I will have to pass. ....
Brian
rwe2156
#8 posted 02-26-2018 05:10 PM
- YesHaveSome
It wasn’t painted besides that the manual does not say anything about painted blades.
It does say not to use blades with anti-kickback (depth limiting) shoulders, tho. That was probably the issue.
View Kazooman's profile
Kazooman
1117 posts in 2072 days
#9 posted 02-26-2018 05:18 PM
I was surprised at how far the blade was from the edge of the riving knife. The blade does not appear to be the diameter that is intended for the saw. I am amazed that he was apparently able to crank the brake cartridge up enough to get close enough so the sensor mechanism would allow him to start the saw. It is the momentum of the blade digging into the aluminum face of the cartridge that sends the blade below the surface of the table. The smaller diameter blade would have much less momentum than a full ten inch blade. Combine that with the anti-kickback blade and the braking mechanism was impaired. It still saved him from cutting his thumb clean off.
View BikerDad's profile
BikerDad
347 posts in 3720 days
#10 posted 02-26-2018 05:39 PM
He said “1-2cm deep” in the video, but I doubt that’s the case. 1-2cm LONG. Had it been that deep, it would definitely have been into the bone, which I’m pretty sure he would have mentioned, given that he did mention the nail damage.
Looks like he dodged a bullet there, and he makes some very good points about paying attention to BOTH hands. Very glad that he didn’t suffer more injury.
-- I'm happier than a tornado in a trailer park! Grace & Peace.
View Rick S.'s profile (online now)
Rick S.
10289 posts in 3152 days
#11 posted 02-26-2018 06:07 PM
I think it was His Mistake …... BUT! $300.00 Bucks & ..... OUCH!
I also think He Was VERY Lucky He didn’t Completely lose His Thumb!!
Rick
-- It is not necessary for Some People to turn OFF the LIGHT to be IN the DARK!
View bonesbr549's profile
bonesbr549
1576 posts in 3186 days
#12 posted 02-26-2018 06:41 PM
Wow so much went wrong there, but he is honest and thanks to him for sharring. Eyes never off that blade ever!
NEVER REACH over a spinning blade! It takes two seconds to turn it off and with the paddle design you don’t even have to look away from the blade, and I’m a lefty.
GRippr’s are you friend and control both sidess. I use two of them!
Finally the average cost of an amputation is 250k and a changed life. I’d say that sawstop has paid for itself in spades!
View pintodeluxe's profile
pintodeluxe
5741 posts in 2932 days
#13 posted 02-26-2018 06:57 PM
I’d be more concerned if I didn’t own a Sawstop.
No safety feature is perfect, but I’ll bet in a majority of cases it helps a great deal.
View Manitario's profile
Manitario
2631 posts in 3002 days
#14 posted 02-26-2018 07:16 PM
I’m an ER doctor and regularly see hand injuries from powertools. The type of injury I see from the mechanism he described, ie. end of thumb going into the blade, typically results in a complete shattering of the bone in the end of the thumb. Those are the ones that end up with the hand surgeon. He has a relatively minor injury, which will heal up quickly, which I think is thanks to the SS safety mechanism.
Rick S.
#15 posted 02-27-2018 10:54 PM
I m an ER doctor and regularly see hand injuries from powertools. The type of injury I see from the mechanism he described, ie. end of thumb going into the blade, typically results in a complete shattering of the bone in the end of the thumb. Those are the ones that end up with the hand surgeon. He has a relatively minor injury, which will heal up quickly, which I think is thanks to the SS safety mechanism.
- Manitario
You’re absolutely Correct Charles! (A Fellow Ontarian I see.)
showing 1 through 15 of 32 replies
