Stanley No. 5 plane restoration question
« back to Hand Tools forum
Forum topic by HandHewn posted 02-25-2018 06:31 PM 594 views 0 times favorited 10 replies Add to Favorites Watch
View HandHewn's profile
HandHewn
7 posts in 222 days
02-25-2018 06:31 PM
Topic tags/keywords: stanley plane stanley plane jack plane no5 hand tools tool restoration tool repair plane repair bench plane vintage plane vintage tools
I’m trying to restore a type 20 Stanley No.5 jack plane that I’ve had lying around for a while to good working condition. Everything seems to be in fairly decent shape except for one crucial component: the y-adjustment lever, AKA the “yoke”, which of course in the type 20’s is a cheesy assembly of two pieces of pressed steel riveted together. On my plane the rivet is broken so the y-adjustment lever no longer functions properly, it just slides past the depth adjustment knob. My question is if it is possible to replace this part with a an older one piece cast iron yoke, or a new one of similar build quality? I figured I could punch out the pin and install a one piece yoke. Has any one done a repair similar to this, and if so what would you recommend as a source for this replacement part?
10 replies so far
View bandit571's profile
bandit571
21057 posts in 2801 days
#1 posted 02-25-2018 06:43 PM
Looks the same as what Millers Falls used on their planes….
View TheFridge's profile
TheFridge
10100 posts in 1604 days
#2 posted 02-25-2018 07:47 PM
Either that or riveting or peining another in.
View BlasterStumps's profile
BlasterStumps
855 posts in 557 days
#3 posted 02-25-2018 08:05 PM
I would think the older one-piece style is interchangeable with the two-piece. Haven’t actually tried it though. I have removed yokes before and reinstalled them. Not much to that except be sure to properly support the cast when hammering on the pin with a punch. I would try to repair that yoke if possible unless that yoke no longer engages the blade; or find a donor plane to rob a yoke off of. just my 2¢
Mike
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
HandHewn
7 posts in 222 days
#4 posted 02-25-2018 09:49 PM
I wonder if this one would work…
https://www.workshopheaven.com/steel-y-lever.html
I would think the older one-piece style is interchangeable with the two-piece. Haven t actually tried it though. I have removed yokes before and reinstalled them. Not much to that except be sure to properly support the cast when hammering on the pin with a punch. I would try to repair that yoke if possible unless that yoke no longer engages the blade; or find a donor plane to rob a yoke off of. just my 2¢
Mike
- BlasterStumps
BlasterStumps
#5 posted 02-25-2018 10:11 PM
I’m assuming you are in the UK… I would contact the company and ask whether it will fit your plane or not.
Mike
View corelz125's profile
corelz125
512 posts in 1094 days
#6 posted 02-25-2018 10:17 PM
Not all of them fit right. I had a broken yoke and replaced it with one i had in a spare parts box and that one did not work right. It could of been from a different company so i would suggest to try and find one from the same time as the one you have. Put a couple drops of oil to help when trying push the pin out.
HandHewn
7 posts in 222 days
#7 posted 02-25-2018 11:25 PM
Actually I’m in the US, the international shipping from that company is fairly pricey :/
I m assuming you are in the UK… I would contact the company and ask whether it will fit your plane or not.
Mike
- BlasterStumps
HandHewn
7 posts in 222 days
#8 posted 02-25-2018 11:38 PM
Yeah I found this one, but it’s from a type 11 which had a smaller diameter depth adjustment knob than the later models, so I imagine it wouldn’t fit my type 20. https://www.ebay.com/itm/VNTG-STANLEY-FROG-2-MOUNTING-SCREWS-WSHRS-FROG-ADJ-BRASS-WHEEL-YOKE-ETC/232677784688?hash=item362cad3c70:g:wLcAAOSwUd9aiL-0
I suppose I could buy an old frog somewhere and pop out the yoke, but I’d hate to take apart a perfectly useable frog, just for that one part.
- corelz125
corelz125
#9 posted 02-26-2018 02:24 AM
There seems to be tons of extra frogs for sale. So you might be able to find a broken one or check just for the yoke alone. You can try a guy deycart he’s a member here and sells a lot of parts on eBay for a fair price.
View Tim's profile
Tim
3812 posts in 2079 days
#10 posted 02-26-2018 02:01 PM
I would also try repair the rivet personally, but if that doesn’t work or you don’t want to try, +1 on contact Deycart to see what he has.
