Need Advice on how to fix this, Please.
Forum topic by tjm5711 posted 02-24-2018 04:10 PM 591 views 0 times favorited 12 replies Add to Favorites Watch
View tjm5711's profile
tjm5711
5 posts in 117 days
02-24-2018 04:10 PM
Would love some advice on how to get this wood simply back in place.
This is a game-used bat, just for display.
Thanks !
12 replies so far
View Lazyman's profile
Lazyman
2050 posts in 1412 days
#1 posted 02-24-2018 04:27 PM
You might just have to completely break it off and then you can just use some wood glue and clamps to reassemble it.
On the other hand, a broken bat usually has a much more interesting story so perhaps just displaying like it is makes it more interesting?
View Loren's profile
10476 posts in 3673 days
#2 posted 02-24-2018 04:27 PM
You could try clamping down the ends over
a fulcrum to bend the bat enough to clamp
the splintered piece in place.
If that doesn’t work I think you’ll need to
split to whole piece off, which may be difficult,
cut it off, which may get ugly, or remove
material from the end of the broken piece.
View Mike_D_S's profile
Mike_D_S
478 posts in 2239 days
#3 posted 02-24-2018 04:33 PM
First off, I don’t think there is any practical way to get that split closed up without it still being obvious the bat was damaged. And there is absolutely no way I would try and close that split with the intention of ever hitting a ball again.
But if the goal is to get it closed to use as the bat as something mounted on a board or other purpose, then there are a couple of ways to do so, more or less successfully.
1. The simple: Using a pair of small needle nose pliers or heavy tweezers, reach in the split where you can and pull out any of the splinters you can get too as close to their base as you can. You can use a combination of a knife and tweezers to work them out. Drive a small wedge into the split to stabilize it and then use a small saw or the knife to trim off the parts of the split piece that stick out and are keeping it from closing up. You should be able to close the split so it’s not that noticeable.
2. The hard: Start the same way by removing any of the splinters inside the split you can. Then in order to close the split without trimming the end, you will have to actually flex the bat enough to create enough bend so you can work the split closed without too much trimming. You could use a piece of 4×4 with some ratchet straps and 2×4 spacers to help create the bend. But I give this about a 50/50 chance of actually working very well, so my recommendation is to go with method #1 above.
Mike
-- No honey, that's not new, I've had that forever......
Lazyman
#4 posted 02-24-2018 04:53 PM
I think that you will get the cleanest glue line if you just completely break it off and glue it back together. This is actually a technique that I have seen used intentionally. The resulting seam after gluing it back together is almost impossible to see without close inspection. Since the break mostly runs along the grain it will continue to split until it comes apart. As long as no splinters are missing (save any that come off while splitting), the glue joint will be nearly invisible, especially if you use a light colored glue such as Elmer’s carpenter wood glue (not the one label “Max” or any others that have a brownish color). A white wood glue would be even better. Just clean off any squeeze-out before it dries.
View Rich's profile (online now)
Rich
2979 posts in 614 days
#5 posted 02-24-2018 05:03 PM
Since it’s display only, why not display it as-is? It’s kind of cool looking and folks will assume it broke when you knocked the game-winning grand slam home run out of the park.
View jbay's profile
jbay
2337 posts in 924 days
#6 posted 02-24-2018 05:15 PM
Fill it with glue, then your going to have to bend the bat enough to pop in the piece that is sticking out.
Then clean off all the squeezed out glue and clamp it. your probably going to have to place the bat, on something you can clamp to, with the bent curve facing up so you can clamp it down to straighten out the curve.
117115 posts in 3602 days
#7 posted 02-24-2018 06:40 PM
+1 Jbay
View Rick's profile
Rick
9725 posts in 3058 days
#8 posted 02-25-2018 01:41 AM
- jbay
What jbay said!
Rick
-- LIFE is what happens when you're planning on doing Other Things!
View Jeff's profile
Jeff
439 posts in 3219 days
#9 posted 02-25-2018 03:03 AM
If you can steam it or soak in very hot water it might bend a little easier.
View Rick's profile
Rick
#10 posted 02-25-2018 03:05 AM
- Jeff in Huntersville
Steaming is a Good Idea Jeff! Huntsville EH? Fished that area many times.
Rick
View Rayne's profile
Rayne
911 posts in 1564 days
#11 posted 02-25-2018 03:06 AM
Was going to suggest this as well. Most wood (I suspect) are pliable when wet enough. Get it back in place and let it dry. Since it’s for display, you really don’t need to glue it back.
View Kazooman's profile
Kazooman
1028 posts in 1977 days
#12 posted 02-25-2018 03:43 AM
I have to agree with Rich. Why not leave it as it is for display. A whole bat is just another whole bat. A broken bat has another story to tell. Perhaps it was not broken when in use for the event you wish to commemorate but at a later date. You could display it as is with a plaque detailing the commemorative event and then adding information of just how the bat met its final demise. Something like “The bat used for TJM’s record breaking three in one game home runs, July 4, 2017. Lost in battle to a foul ball August 12, 2018”.
