Bed Slats ..New you tube
Forum topic by CharlesNeil posted 02-24-2018 01:12 PM 363 views 0 times favorited 10 replies Add to Favorites Watch
View CharlesNeil's profile (online now)
CharlesNeil
2434 posts in 3985 days
02-24-2018 01:12 PM
https://youtu.be/bdNcmLRMKgQ
yea yea I know, Bed slats of all things, but we do ours a bit different , and it works great .
10 replies so far
View Monte Pittman's profile
Monte Pittman
29784 posts in 2453 days
#1 posted 02-24-2018 01:27 PM
Excellent tips. I use plywood under the mattress (although didn’t occur to me to finish it). It obviously takes 2 pieces across the bed. Do you laminate them into one piece or leave them as 2?
CharlesNeil
#2 posted 02-24-2018 01:29 PM
Just leave as 2 pieces Monte .
View Tennessee's profile
Tennessee
2880 posts in 2629 days
#3 posted 02-24-2018 01:44 PM
Fascinating. If you did that plywood trick on a modern metal frame, would there be a benefit for seniors who may have a problem in the morning putting on things like shoes and slippers, while they sit on the edge of the mattress? Just a thought. Only reason I bring it up is I have a bad back and one replaced knee, both of which have less flexibility than when I was a young buck. Harder to put on my shoes!
On the other hand, it might end up too low and they might not be able to stand up from the mattress.
CharlesNeil
#4 posted 02-24-2018 01:53 PM
Tennessee,
Your correct , With a bed frame you probably do want a box spring to get the height,
I have built a ton of beds, a good general rule of thumb is you want the mattress height to hit just at the bottom of your butt cheeks, may sound nuts , but at that height , you simply sit down to get in bed and stand up to get up.
We have used this formula forever and never had a client who didnt like it , it relieves that lumbar strain
That height is usually around 28 to 31 ”.
Problem is many mattress’s are 10 to 20 thick and 4 to 8 on the box spring, and on a period bed where we want to sit the side rail well off the floor, usually 10 to 12 ” , the bed gets too high, this is where the plywood comes in, or I have even build a ” platform”, like framing a wall, to get a specific height which could also be employed on a bed frame .
View jbay's profile
jbay
2580 posts in 1014 days
#5 posted 02-24-2018 02:53 PM
I’m building a daybed right now.
I’m building a base for the mattress, but instead of plywood I’m using melamine.
I think the trade off from having to finish the plywood, compared to the melamine having a PB core is worth it?
CharlesNeil
#6 posted 02-24-2018 03:17 PM
jbay
Sounds like a good idea to me .
BTW, like the design .
117203 posts in 3692 days
#7 posted 02-24-2018 03:25 PM
Another super tip Charles, another example of the quality you put into your furniture.
View GR8HUNTER's profile
GR8HUNTER
4531 posts in 827 days
#8 posted 02-24-2018 03:28 PM
THANKS :<))
Monte Pittman
#9 posted 02-24-2018 03:52 PM
How thick of plywood do you use?
CharlesNeil
#10 posted 02-24-2018 11:41 PM
Monte.. 3/4 is my go to
