Tack cloths, How important ?
Forum topic by MrWoody posted 252 days ago 705 views 0 times favorited 32 replies Add to Favorites
View MrWoody's profile
MrWoody
236 posts in 303 days
252 days ago
Topic tags/keywords: sanding finishing
Ok, I just spent 2 days sanding.(Maybe with a few longesh breaks, I hate sanding). I know I should use tack cloths before finishing, but recently there was something about them possibly being responsible for fish eye.
So is there an alternative method for clean up before finishing ?
-- If we learn from our mistakes, I'm getting a fantastic education.
View GaryK's profile
GaryK
8541 posts in 516 days
252 days ago
Not sure about fisheye. I usually use compressed air. I think it’s way better than a tack cloth.
View toyguy's profile (online now)
toyguy
483 posts in 365 days
251 days ago
Yip, I too use the compressed air method. No compressor, no problem, try a can of air.
4486 posts in 746 days
251 days ago
What finish in particular?
I don’t do much lacquer, but for poly I just wipe down with a mineral-spirits-dampened rag.
9724 posts in 350 days
251 days ago
Fish eye is generally not a problem with tack cloths. Instead what they do is transfer chemicals to the wood that may interfere with the stain/finish. It is better to use compressed air or a clean cloth with mineral spirits to remove the dust and sanding grit between each individual grit that is used in the sanding routine.
Douglas Bordner
2707 posts in 592 days
251 days ago
And those micro-fiber tack clothes work as well, as long as you aren’t transferring the offending chemicals in the same manner as a regular tack cloth. If you are using the compressed air technique, try doing it in an area other than the spray site, or let the air settle before firing up the spray gun.
The regular tack cloths can be a problem with waterborne lacquers.
View Peter O's profile
Peter O
669 posts in 403 days
251 days ago
I’ve heard the compressed air method before, and I use compressed air as a first step, but even though I use a blow nozzle at 110psi a couple of inches from the wood I still find a layer of very fine dust is left on the surface. I’d love to skip the tack cloth step, but I’ve never found that air alone would get my pieces clean enough.
I’ve used the waxy cloths without any fish-eye until recently (and I’m not positive that my problems were caused by the tack cloth), but the microfiber cloths seem to do just as well and last longer.
-- Coffee is best with a fine layer of sawdust on top. -- http://www.north40custom.com
MrWoody
251 days ago
I love this site. You ask a question and get 6 replies in a couple of hours.
I’m not sure that blowing the dust off is a good idea in my 12’ X 20’ ft. wood, metal, welding shop and finishing room. I’m going to be using a wood conditioner that calls for Mineral Spirits for clean up. Now I’ve never used a wood condidtioner before, so can I assume that wiping down with it won’t be a problem?
Should I leave it dry over night before applying the conditioner? I can leave the air cleaner running over night as well. That should keep too much dust from settling on it.
View Safetyboy's profile
Safetyboy
66 posts in 287 days
251 days ago
I usually wipe down with mineral spirits before staining, mostly to look for glue spots… but I also have used tack cloths between coats of poly, on a number of projects, and never had a problem. I’m transitioning to microfiber cloths for that now though – I think I like them better – my hands don’t get so sticky.
-- -- Kevin in Mentor, Ohio
View gizmodyne's profile
gizmodyne
1479 posts in 618 days
251 days ago
I always tack cloth. No problems yet.
View jeffthewoodwacker's profile
jeffthewoodwacker
202 posts in 332 days
251 days ago
I use compressed air and a clean cloth with mineral spirits.
-- Genius is immediate, but talent takes time.
View mrtrim's profile
mrtrim
1548 posts in 408 days
251 days ago
the reason you get fisheyes from a tack rag is usually applying too much pressure on them . the concept is too litely drag the cloth over the surface and the dust sticks to the wax . when you use too much pressure it can transfer the wax onto your piece . on smaller pieces i choose to use my clean bare hand because i can feel the dust that i cant see .
teenagewoodworker
2126 posts in 296 days
251 days ago
i use compressed air but i have used tack clothes in the past and they work good too but on porous woods compressed air is better because the cloth doesn’t clean out the pores well. otherwise tack clothes work fine in my opinion.
251 days ago
Wood conditioner is simply a diluted finish. You can either buy it premade or make your own. Examples of conditioners are:
1 pound cut of shellac
lacquer 1:1 with lacquer thinner
thin varnish/oil poly with 2 parts of mineral spirits to 1 part of varnish/poly
Bulls eye shellac is available in both a 2 and 3 pound cut. Just thin with alcohol to desired cut.
Hope this helps.
View Myron Wooley's profile
Myron Wooley
164 posts in 424 days
251 days ago
I use a shop vac with HEPA filter and a soft bench brush. Tack cloths can contaminate the surface, and air compressors just launch the dust into the air. What goes up must come down, and it will probably come down on your nice, sticky fresh coat of finish.
-- Furniture Medic- the prescription for damaged furniture
12249 posts in 689 days
251 days ago
in one of my interviews I did (I forget which one), when I asked “any tips for LumberJocks” the quick reply was GET RID OF THE TACK CLOTHS”.
or something like that :)
View jerry mayfield's profile
jerry mayfield
9 posts in 613 days
251 days ago
Tack clothes are what we woodworkers keep our dirt,grease,lint ,oil and other contaminates in so we can apply them to the next piece we finish.
Regards
Jerry
-- jerry,mlchigan
Douglas Bordner
250 days ago
Although I believe at least one jock here has had no problem using standard shellac, I would point out that Zinsser Sealcoat is a 2 lb cut of dewaxed shellac that is warranted to be compatible under any clearcoat without causing adhesion difficulties, has some process applied that provides for extended shelf life and has been picked up over the last few years by Lowe’s/Menards/Home Depot. There is a manufactured date on the bottom and the stuff seems to move fast enough that one has little to fear that it has gone over the pale. Old shellac just never hardens, which as you might guess, is a good way to screw up a nice project.
Cut 1:1 with denatured alcohol it makes a superb wood conditioner, perfect under dyes and stains for woods with a tendency to blotch (pine, cherry).
Shellac is one hundred percent safe even on baby furniture etc., and can be padded on fast and rubbed out between coats in an hour or less. While not as heat or water resistant as poly or alkyd varnish, it is a very forgiving and convenient topcoat. Love the stuff…
View brunob's profile
brunob
1391 posts in 698 days
250 days ago
I too use tack clothes with no problem. They get very fine dust off even after I’ve used air.
-- Bruce from Central New York
View brianinpa's profile
brianinpa
923 posts in 251 days
249 days ago
I always used tack cloths and had no problem with the finish. I stopped using tack cloths becasue I got an air compressor. There is a lot less effort to remove dust when using an air hose.
View Pretzel's profile
Pretzel
95 posts in 274 days
249 days ago
I agree with Myron, vac. & brush, then spray to your little hearts content
-- Pretzel L8agn
View Woodshopfreak's profile
Woodshopfreak
331 posts in 270 days
248 days ago
I agree with everyone. I use tack cloths but compressed air is probbobly better. It would take alot less effort, and plus tack cloths are just annoying.
-- Tyler, Illinois
View Dadoo's profile
Dadoo
1549 posts in 519 days
248 days ago
I always go with compressed air. Gives the shop that fresh cut wood aroma, ya know?
View DAN's profile
DAN
3461 posts in 511 days
232 days ago
my methods of finishing really has no need to blow off the dust or wipe it off before I apply finish to my work.
After I sand to 220 I apply lots of alchohol dye stain. Before the dye is dry, I apply liberal amounts oil stain. I then rub the oil stain with 0000 steel wool or beartex. I then use a cloth to wipe off the excess stain and let it dry.
when the stain is dry I apply shellac with a small cloth blob … usually about 3 coats
top coat is dark paste wax rubbed around with 0000 steel wool and buffed with cotton cloth
-- ..... art for lifes sake ... danwalters@lumberjocks.com
View RAH's profile
RAH
310 posts in 405 days
232 days ago
Obviously wood working is not just about cutting wood and sticking it together, after reading this I now know I have much to learn about just prepping the wood to get a proper finish. I am looking forward to retirement so I can make wood working a full time job. I use compressed air, my hands are so dry tack clothe sticks to them.
-- Ron Central, CA
View ND2ELK's profile
ND2ELK
2556 posts in 302 days
232 days ago
I have always vacumed my cabinets off with a brush attachment before finishing.
God Bless
tom
-- Mc Bridge Cabinets, Iowa
View SteveKorz's profile
SteveKorz
1414 posts in 242 days
232 days ago
This site is great… there is so much info here…
I use tack cloths and air nozzle, about 50/50. I’ve never had any problems with either.
-- As iron sharpens iron, so one man sharpens another. (Proverbs 27:17)
View Al Killian's profile
Al Killian
203 posts in 281 days
230 days ago
First I blow the dust off, then wipe it down with a damp cloth. This will remove the dust and leave the wood clean.
teenagewoodworker
82 days ago
the tack cloths that you buy at the stores a usually cheesecloth saturated in BLO. so if you use it before an oil based finish you are good. the problem is using it before a waterbased or a lacquer. then you will get adherence problems. if you are going to do that you need to go to an autobody supply store and get tack cloths there. they are higher priced but designed to be used under water based.
View cmaeda's profile
cmaeda
98 posts in 82 days
81 days ago
I have tried compressed air but it doesn’t work for me since my workshop is a two car garage. I first use my shop vac to get as much dust off as possible. I keep the shop vac as far away as possible to avoid kicking up more dust around me. The car nozzle works really well in some of the tight spots.
Then I use a tack cloth to get every last bit of dust. I have used a clean cotton t shirt soaked in mineral spirits when I don’t have a tack cloth and it seems to work pretty well too.
View trifern's profile (online now)
trifern
4803 posts in 295 days
81 days ago
I use a clean rag soaked in mineral spirits. I feel my work a lot to make sure it feels as good as it looks. The mineral spirits removes the oil from my hands as well as the dust. It will also highlight areas that still need work. Thanks for the topic.
View Paul 's profile
Paul
46 posts in 118 days
81 days ago
If you use microfiber cloths (or any other fabric) it should be washed without bleach and dried without fabric softeners. Both leave residue on the fabric that can transfer to the wood.
-- Paul, Washington State
View Critterman's profile
Critterman
484 posts in 338 days
80 days ago
Wow, lots of ideas here, so let me add my two cents…Vacuum are said to be a bad idea since the best way to use it is with a brush and the brush can leave scratch marks (like sand paper) or at least that’s what I was told. The old compressor idea works well, except now you have all that really fine dust in the air and it will stay suspended up there for a good while, even with an air cleaner sometimes. So, I learned from a renowned woodworker the old mineral spirits work great, get the dust off and show any imperfections at the same time. I see Kevin and trifern also mentioned this. Been using it for a while and it does work very well. It evaporates and leaves nothing but clean wood behind, oh another benefit; it will clean any oily stuff off as well. It’s a good deal all around and it has been better for me than anything else I’ve tried include those listed above. Oh, just make sure you have good ventilation; passing out in the shop isn’t a fun experience.
-- Jim Hallada, Chesterfield, VA
Bookmark And Share This Page
