Is this normal? (90 degree stop)
Forum topic by LucasWoods posted 02-23-2018 04:56 AM 1343 views 0 times favorited 10 replies Add to Favorites Watch
View LucasWoods's profile
LucasWoods
445 posts in 1539 days
02-23-2018 04:56 AM
I am tuning up my saw and checked my 90 degree stop (with a digital magnetic angle guage stuck directly to the blade) I found I was a half degree off from 90. As I continued to move my guage I found that I had to actually put some washers between the stop and the trunnion.
See picture below.
Is this normal to have to do? I have an old G1022 TS
-- Colorado Springs, CO - USAF
10 replies so far
LucasWoods
#1 posted 02-23-2018 05:03 AM
Idk why but I think my digital angle guage is off somehow? When I stick it to the blade (magnetic base) it shows it is off from 90. But when I check with my square it shows that it is spot on with no gaps.
View Loren's profile
10477 posts in 3854 days
#2 posted 02-23-2018 06:11 AM
Did you flip the gauge around so the same
side is facing up when you measured?
Just occurred to me.
Somebody else posted recently about those
box gauges being off when checking the other
side of a saw blade.
View toolie's profile
toolie
2148 posts in 2834 days
#3 posted 02-23-2018 12:50 PM
Good suggestion regarding handling the angle cube. Given the sawdust can accumulate on the stop and affect its accuracy, I never use the stops on either of my saws. It’s surprising how little sawdust it takes to affect the angle.
View Steve's profile
Steve
756 posts in 788 days
#4 posted 02-23-2018 01:52 PM
It’s hard to explain, but those angle cubes are only designed to give you the angle of something in relation to whatever surface you zeroed it out on.
Also, make sure you aren’t attaching it to the blade near the teeth.
View Carl10's profile
Carl10
109 posts in 662 days
#5 posted 02-23-2018 02:10 PM
As Loren mentioned there was a discussion about the inaccuracies of those cubes. I have one and tried the same thing are doing to square up my blade. I would get it square and then the tried the other side of the blade would measure 89.9 degrees. But the accuracy of the gauge is only +/-0.2 degrees so it was within tolerance. The other thread referenced a FWW article (237 I believe) that tested these gauges and found gaps between the blade and a square (drafting square, I believe) when these digital gauges measured 90.
So it appears the digital gauge cubes are not the jog for blade angles.
Hope that helps.
Carl
View ArtMann's profile
ArtMann
1161 posts in 1022 days
#6 posted 02-24-2018 12:59 AM
Most saws have 90 and 45 degree stops that are adjustable. They typically involve adjustable stops on the screw mechanism or something similar.
View Lazyman's profile
Lazyman
2644 posts in 1593 days
#7 posted 02-24-2018 03:10 PM
My Wixely digital angle gauge seems to be very accurate. If I zero on the table, move it to the blade adjust it to 90, rezero and move it back to the table, it will read exactly 90 again.
Perhaps I am not interpreting what I see in the picture correctly. I see the washers you stuck in there and I see a bolt with a jam nut on it but it should be sticking out the other side of the stop for setting it to 90. It might be as simple as loosening the nut so you can turn the bolt to the same point as those washers are holding it and then tightening the jam nut to lock it in place. There should be another similar one on the other end to set it to 45.
Note: Even with my 90/45 stops set close to perfect, it is still possible to pass the setting by over tightening so I generally have to stop as soon as there is any resistance. The stops are good enough for government work but if you need precisely 90 or 45, measure.
View John_H's profile
John_H
188 posts in 1912 days
#8 posted 02-24-2018 04:25 PM
I am not familiar with that saw, but looking at the pic – isn’t that an adjustment screw with a lock nut directly below where the washer is placed?
View 489tad's profile
489tad
3473 posts in 3217 days
#9 posted 02-24-2018 04:43 PM
My Wixely is also accurate. Zero it on the table then check the blade. Cross cut a board, flip over one half and match the cuts. If there is no gap your good to go. If not you’ll be able to adjust the blade to the right direction.
-- Dan, Naperville IL, I.G.N.
ArtMann
#10 posted 02-24-2018 04:50 PM
W-I-X-E-Y
