Is there a way to replicate the smoothness of wood that has been touched by hand multiple times?
Forum topic by EricWrights posted 765 days ago 762 views 0 times favorited 7 replies Add to Favorites Watch
View EricWrights's profile
EricWrights
94 posts in 1417 days
765 days ago
Topic tags/keywords: wood working
You know how park trees have areas that every kid who has climbed it uses and become super super smooth due to the thousands of hands touching them over the years, or on really old wooden handrails, wooden playground equipment etc?
Is there a practical way of replicating the intense smoothness of that wood?
-- Sawing, sanding, scraping, cutting? Let Rockwell Sonicrafter do the job. http://rockwellsonicrafter.com & A more general blog at http://resay.org
7 replies so far
View bubinga's profile
bubinga
867 posts in 834 days
#1 posted 765 days ago
Or you could rub it with rocks or dirt
-- E J ------- Always Keep a Firm Grip on Your Tool
View rhett's profile
rhett
553 posts in 1833 days
#2 posted 765 days ago
I think it is a combination of fine smoothness and the natural oils from human hands.
Therefore, my suggestion is to raw sand up to around 400 grit and then wet sand a grit higher with automotive sandpaper soaked in linseed or danish oil.
-- http://www.niceashplanes.com/ http://www.efcabineture.com/
View DaleM's profile (online now)
DaleM
800 posts in 1550 days
#3 posted 764 days ago
You could do what the others suggested, but if you finish off with burnishing it by rubbing another piece of wood against it, it will be even smoother. You do have to apply some pressure, not just rub lightly with the wood.
-- Dale Manning, Carthage, NY
View Loren's profile
4870 posts in 1814 days
#4 posted 764 days ago
There’s an abrasive quality to your skin, like a leather strop. In fact
you can strop a knife on the palm of your hand.
In the old days they used to polish and smooth wood and finishes
with abrasive leaves from plants.
Sand it until you can only make out fine scratches, then you could
buff with a wheel – with or without compound. You can try automotive
buffing compounds and see what happens.
A light-colored oil may work well. “salad bowl” oil would probably work
well. I think linseed oil might be a little too dark.
View gfadvm's profile
gfadvm
6611 posts in 856 days
#5 posted 764 days ago
Start with a dense wood [Brazilian Cherry is my favorite],sand to 180 or 220,apply blo,rubbing in well,then wax with Renissance Wax.This produces the most touchable finish I have found.Sanding through finer grits does not produce any improvement in touchability that I can perceive.IMHO.
View rance's profile
rance
3855 posts in 1326 days
#6 posted 764 days ago
Its called a hand rubbed oil finish. :D Oh, and the oil is free.
View Glen Peterson's profile
Glen Peterson
317 posts in 1222 days
#7 posted 763 days ago
I once met a fellow who makes wooden spoons and utensils. He doesn’t use sandpaper. After carving and shaping he puts them in water and then scrapes them smooth. I don’t remember what he used for scraping, but he would repeat this soaking and scraping process numerous times and get an incredibly smooth feeling result, like old driftwood.
-- Glen
