Advise on router plates with 3.5'' panel bits
Forum topic by kdr152004 posted 02-22-2018 02:56 AM 1335 views 0 times favorited 11 replies Add to Favorites Watch
View kdr152004's profile
kdr152004
25 posts in 805 days
02-22-2018 02:56 AM
Dear lumberjocks,
Waddya know, smack in the middle of making a practice cabinet door for my new kitchen, I realize that my Freud ~3.5’’ diameter raised panel bit does not fit through the opening of my Rockler phenolic plate w/ Dewalt DW618 router – refer to picture.
Can anyone recommend a base plate to use with a DW618 and a large panel raising bit , or an alternative settup? I’m leaning towards the Kreg plate, as I would like to have the leveling screws.
Any guidance much appreciated
11 replies so far
View Rich's profile
Rich
2960 posts in 611 days
#1 posted 02-22-2018 04:13 AM
The JessEm Mast-R-Lift II will handle that. However, given what you’ve got and the fact that it’s phenolic, I’d see if I could use that bit to cut the opening large enough to fit. Obviously not with the router spinning, but perhaps you could turn it by hand and shave away the phenolic. You don’t need much clearance, only enough for the router bit to spin.
View RDan's profile
RDan
64 posts in 2346 days
#2 posted 02-23-2018 04:47 AM
You could just make a temporary top, with a hole the size you need for it out of MDF. The Late Pat Warner always suggested this. Or buy another phenolic Plate to dedicate to that bit. I have one that size too, I will have to check it now. Dan
View copythat's profile
copythat
128 posts in 628 days
#3 posted 02-23-2018 04:51 AM
That looks terrifying. i hope the collet is sound and there is no bit creep.
Just curious but how big is too big in a router? At what point should you turn to a shaper?
-- Rob
View Rich's profile
Rich
#4 posted 02-23-2018 05:56 AM
I use a 3-1/2 inch panel raising bit in my JessEm. It works like a champ. The only factor to consider is the router and even with a smaller one, you can do it with multiple passes. The Bosch 1617 can handle panels in one pass without a hiccup. I’ve run panels for over 100 doors and it’s still going strong.
View LazarusDB's profile
LazarusDB
25 posts in 187 days
#5 posted 02-23-2018 01:08 PM
I love my Incra router lift and it will handle a 3 1/2” bit. Like Rich said, you need to take multiple passes on larger bits. Good luck.
-- Aaron - Aspiring Craftsman
View Tennessee's profile
Tennessee
2873 posts in 2536 days
#6 posted 02-23-2018 01:26 PM
I used to add German Curves to my guitars with a 3” bit mounted in my handheld Bosch 1619. It would try to gyro once up to speed, and I had to clamp down the guitar bodies. I also had a Freud 3.5” raised panel bit that I did the same thing, which made the guitar look somewhat like an archtop. Did that probably four or five times over the years. The router was variable speed, and I did slow it down to about 75%.
Now that I think about it, what was I thinking??
View Markmh1's profile
Markmh1
73 posts in 465 days
#7 posted 02-23-2018 03:52 PM
If that were my problem, I’d use a spindle sander to schnaggle the hole bigger.
Without a spindle sander, I’d make a trip to the hardware store to buy a sanding arbor I could use in a drill press.
Good luck
Mark
kdr152004
#8 posted 02-23-2018 04:28 PM
Hi all,
I’m now leaning towards the Jessem Rout R Lift 2, which is expensive, albeit reasonably priced. Overall, between the plate lacking any leveling system, the insert ring sitting slightly beneath the plate, and the mediocre dewalt fixed base height adjustment, it just makes more sense not to cheap out when making doors for my own kitchen.
I played around with the temporary top idea , but since I am a 1 man hobby shop and my time is limited, I’d rather not spend it fussing with bit-specific setups if not needed.
View Sawdust35's profile
Sawdust35
30 posts in 884 days
#9 posted 02-23-2018 08:50 PM
I’ve used a Freud raised panel bit (99518) and whiteside panel bit (6000B). Both bits fit in my rousseau router table insert http://rousseauco.com/phone/3509-router-base-plate.html and my jessem mast-r-lift II.
View Peteybadboy's profile
Peteybadboy
293 posts in 1971 days
#10 posted 02-23-2018 09:00 PM
There are plates that have changeable rings of different sizes. Mine is a pinnacle. (no longer made) There are others.
-- Petey
kdr152004
#11 posted 02-26-2018 07:08 PM
While the Rockler was a quality product for the price, I’ve switched to the Jessem Rout-R-lift which gives me a lot more control over the plate level-ness and the height adjustment. Thanks all for advice. Will post a picture of my setup soon.
