6 inch dust collector pipe??
Forum topic by mousejockey posted 02-21-2018 06:45 PM 392 views 0 times favorited 6 replies Add to Favorites Watch
View mousejockey's profile
mousejockey
69 posts in 2964 days
02-21-2018 06:45 PM
Topic tags/keywords: dust collection
I have several used pieces of 6 inch metal duct and it’s a pain to work with. It comes in fixed lengths and since I had used it previously the ends are dinged and bent and I have to go back and seal all of the joints. I use mostly 4 in. sewer pipe to the machines.
Is there a plastic 6 in. pipe that is not too expensive? I looked at HD and Sch 40 10 ft is ~$40 and the fittings are expensive as well.
TIA Myles
View AZWoody's profile
AZWoody
1346 posts in 1246 days
#1 posted 02-21-2018 06:59 PM
6” S&D is what I use. I get it at a plumbing supplier. The bog box stores don’t carry it normally. They might be able to order it though.
View jonah's profile
jonah
1720 posts in 3321 days
#2 posted 02-21-2018 07:09 PM
Look for the kind of 6” pipe landscapers use, if you can find it. It’s very thin walled and so is less expensive than S&D pipe. I forget the schedule number.
You’ll never find it at a big box store, in my experience.
4996 posts in 2515 days
#3 posted 02-21-2018 08:32 PM
6” thinwall (also called DWV, soil pipe, and several other names) it will be marked ASTM D2729 on the side. It’s been awhile sine I bought any but it was about $20 for a 10’ length. I also snagged some at the local Habitat store, a little dinged around the ends, but they wanted an offer…I gave them $5 each for 3 pieces. This stuff can be a little hard to find in 6” size, check local plumbing specialty houses, farm stores, and the small local lumber yeards. If you have a Menards nearby, they have 6” in 3034. It’s quite a bit heavier, but the stores I have get about $20 for 10’ on it and the thinwall fittings work.
View John Smith's profile
John Smith
989 posts in 185 days
#4 posted 02-21-2018 09:49 PM
my brother has used the landscape drain pipe and it worked for him.
I think he had a screen to keep out the big pieces and long splinters.
there is an assortment of fittings that can be used to make a “system”.
easily sealed with duct tape and mastic.
-- Graduated Valedictorian from the University of HardKnocks --
View Kazooman's profile (online now)
Kazooman
1024 posts in 1974 days
#5 posted 02-21-2018 10:10 PM
my brother has the landscape drain pipe and it works for him.
I think he has a screen to keep out the big pieces and long splinters.
- John Smith
I would be a bit concerned about the corrugations creating some turbulence and reducing airflow. I would prefer a smooth walled pipe.
John Smith
#6 posted 02-21-2018 10:33 PM
Tia – what lengths are you talking about for your entire system ?
photos of what you have may provide more accurate responses.
Kazoo – that was my question too – but that is what he used and it worked for him.
[I guess it depends on the power of the exhaust system and footage involved].
I agree with the 4” sewer drain pipe to be the most cost efficient and easy to work with.
schedule 40 PVC can get expensive for long runs.
