The only way I can make money with wood
« back to Sweating for Bucks Through Woodworking forum
Forum topic by Stormin posted 04-14-2011 08:54 PM 3228 views 0 times favorited 15 replies Add to Favorites Watch
View Stormin's profile
Stormin
193 posts in 2785 days
04-14-2011 08:54 PM
I know this has been brought up many times before. So with tongue in cheek, here is how I make money with wood. Take a 50’ Western Clear Cedar and some 4”X 5” fir timbers add a bunch of hardware. It’s a done deal. Please don’t take this to serious :-)
-- I started off with nothing I have most of it left
15 replies so far
View Bertha's profile
Bertha
13525 posts in 2688 days
#1 posted 04-14-2011 08:57 PM
Can I ask you an electrical question? Just kidding. That’s probably the most expensive project on this site! Strong work.
View Earlextech's profile
Earlextech
1161 posts in 2686 days
#2 posted 04-14-2011 09:05 PM
No finish huh?
Bertha
#3 posted 04-14-2011 09:11 PM
^laughing with Sam. Hard.
Stormin
#4 posted 04-14-2011 09:43 PM
I’m sorry Sam I should have mentioned the bottom 10 ft and the timbers ( cross arms ) are finished with Pentachlorophenol I’m glad you guy’s are seeing the humor in this. I should have mentioned that this distribution is being installed to supply power to a new type of Kiln in this area, used to remove the moisture from lumber. Instead of steam they are using large refrigeration compressors , like heat pumps to remove the moisture they will also use gas fired heaters and the end of the process to bring the moisture content down to 14%.
Bertha
#5 posted 04-14-2011 09:47 PM
Did you raise the grain before you applied the PCP? Wetsanded or handrubbed?
View degoose's profile
degoose
7233 posts in 3350 days
#6 posted 04-14-2011 09:52 PM
Funny…
Stormin
#7 posted 04-14-2011 09:58 PM
Bertha I have to confess I had a professional do the PCP. :>)
View RexMcKinnon's profile
RexMcKinnon
2593 posts in 3191 days
#8 posted 04-15-2011 07:17 PM
LOL… watch, over the next 3 months every 3rd project will have something electrical in it. ;)
-- If all you have is a hammer, everything looks like a nail!
View Verna's profile
Verna
202 posts in 2769 days
#9 posted 04-15-2011 08:16 PM
Yeah, but you cheated by having a lift. Where’s your hooks/gaffs? Great project, and yes, I’m sure it will definitely be a very expensive one!!!!
-- Verna -- Indianapolis, IN
View pete79's profile
pete79
154 posts in 3136 days
#10 posted 04-15-2011 08:26 PM
Can you please explain the joinery? It seems like this might be an advanced technique, but it’s hard to tell from the pics. Closeups would be appreciated. ;-)
-- Life is a one lap race.
View ChuckV's profile
ChuckV
3118 posts in 3523 days
#11 posted 04-15-2011 08:58 PM
Did you also build the one on the right in the second picture? It almost looks like a real tree – amazing work!
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
View Lee Barker's profile
Lee Barker
2170 posts in 2846 days
#12 posted 04-15-2011 10:32 PM
I’m curious about the lathe work: chisels you prefer, and the size and length of your tool rest.
Do you leave the marks from the centers on, or cut them off?
Kindly,
View JJohnston's profile
JJohnston
1622 posts in 3287 days
#13 posted 04-15-2011 10:37 PM
Let’s see…you cut down a tree, cut off all the brances, then put it back up and put the branches back on.
Sounds sane to me!
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View Gene Howe's profile
Gene Howe
10479 posts in 3424 days
#14 posted 04-15-2011 11:48 PM
Nice example of your current work. Absolutely electrifying!
Thanks for making my day…A day without humor is just….revolting.
Stormin
#15 posted 04-16-2011 12:32 AM
Thanks for the comments I’m glad you LJ’s can see the humor in this. Verna we had to use a lift there was no more room on the pole for climbing, the hooks are in the truck. The joinery is good old fashioned butt joints.The one on the right was done by someone higher up. We didn’t have a large enough lath so it had to be peeled. I just hope when we plug it in it doesn’t glow. :-)
