| Forum topic by Jack_Isidore | posted 765 days ago | 1483 views | 0 times favorited | 11 replies | ![]() |
765 days ago |
Topic tags/keywords: welding metal tubing metal tubing tig mixed materials materials I’m taking a tig welding course over the summer in the hopes of using steel (and maybe aluminum) for components in some mostly wood furniture. So far, all I can find locally is structural steel tubing, which has a larger radius than you see on furniture tubing. Any ideas on particular suppliers, or a better google search term? I’ve gotten a few dead end results trying for “decorative steel tubing” and “architectural steel tubing”. I know this is probably a question better suited to a welding forum (which I’m not on any) but I thought surely some of you have used metal tubing in your furniture. |
11 replies so far
#1 posted 765 days ago |
Electrical conduit is your best bet for practice material. You can get it just about anywhere and it is cheap. Just use lots of ventilation and preferably work outside. I don’t know what coatings it uses internally and it does have some zinc on the outside. -- Woodworking shouldn't cost a fortune: http://lowbudgetwoodworker.blogspot.com/ |
#2 posted 765 days ago |
http://www.aircraftspruce.com/catalog/mepages/4130tubing_un1.php I searched for “thin wall steel tubing” and found some RC guys discussing |
#3 posted 765 days ago |
Woops, I should clarify, I am looking for square and rectangular tubing. That’s what I meant when I said I can’t find tubing with a small radius. All the structural square tubing I can find has very rounded corners. |
#4 posted 759 days ago |
Jack – try looking for aluminium box-section. Stainless steel box-section is also available in a variety Hope this helps, -- A family man has photos in his wallet where his money used to be. |
#5 posted 759 days ago |
You mentioned which has a larger radius, are you looking to purchase stock bent to a radi, or are you looking for stock that you can bend on your own? -- E J ------- Always Keep a Firm Grip on Your Tool |
#6 posted 759 days ago |
You want stock with 90° square corners, as opposed to around over corners, is that correct? -- E J ------- Always Keep a Firm Grip on Your Tool |
#7 posted 759 days ago |
I’m jealous—would love to have time/money to learn to weld. Have fun! Try here: McMaster-Carr We occasionally specify products from Julius Blum but I’ve never bought from them—don’t even know if they sell direct. |
#8 posted 759 days ago |
Murch, my first glance at a google search looks like box section may be the terminology I was looking for. Thanks. Bubinga, to clarify, I am looking for square or rectangular cross sectional tubing that has small radius corners, I am not actually trying to bend the tubing myself. The application is table legs or other framework. Here is a sketch of what I’m talking about. These are the cross sections of two types of tubing. The one on the left is what I’m trying to find in stainless and or non-stainless alloy, and the one is the right which is more like structural steel tubing that I have found locally.
Unfortunately for me, the SS tubing mcmaster has doesn’t specify a radius or provide 3d cad (or drawings). I may be wasting my time looking all over when the first day of class the instructor might be able to tell me exactly where to go to find this… Still, that’s a month or two away, I was hoping to get some ideas of prices so I can design a project in advance. |
#9 posted 759 days ago |
Hmmm… finding hard numbers for the corner radii tends to be extremely difficult; I’d be interested to hear if you find a place which lists this upfront. That radius will vary from mill to mill, and suppliers will sell the products of multiple mills under the same item number, since the rough dimensions are the same. Is your design that dependent on the exact radius? If so, I’m guessing that you’re going to need to start calling suppliers and/or the mills themselves, unless you’re willing to take a chance on ordering some material. |
#10 posted 759 days ago |
That’s true, they may not be supplied. Although my design doesn’t depend on it, I just want to get a general idea of what it is. I want it to be relatively small, but what exactly it is, isn’t a concern. |
#11 posted 759 days ago |
You might have luck if you take the picture to your local suppliers and ask if they can get anything. Talking to the teacher or other metal/welding people might help also. The picture will help you clairify what you are looking for and they might beable to give you better search results. -- ----- www.KNWoodworking.com ----- -- |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3542 |
15752 |
Hand Tools
2029 |
Jigs & Fixtures
494 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
