First post on lumberjocks - a lesson learned in pain
Forum topic by CADguy posted 766 days ago 800 views 0 times favorited 7 replies Add to Favorites Watch
View CADguy's profile
CADguy
5 posts in 766 days
766 days ago
Topic tags/keywords: oops finger cut off ridgid 14 bandsaw band saw safety lesson
Hello all, i recently had an accident resulting in a trip to the ER I thought I’d share as my first post on lumber jocks. Before i start, I want to make sure you don’t get me as an idiot who is careless, etc. I am very anal about safety and know my own boundaries. Here we go: Well, I have a 14” ridgid bandsaw and put on a brand new 1/8” timber wolf blade last week. I removed the rear guard to install the blade and forgot to put it back. I was cutting out my 3rd little 1/8” thick bunny rabbit shape(for my kids to paint) and went to reach for the off switch and found out how sharp that new blade was. I actually ended up a little lucky really as I only got the tip of my middle finger; it could have easily been 3 or 4 fingers in the middle of joints, etc. . The blade entered on the fingerprint side and went all the way through the bone and actually notched both sides of my fingernail before I yanked it away in agony. So the only part of the finger that wasn’t severed was about 1/2 the thckness of the arch of my fingernail. The end result yielded 8 stitches and what is still a very sore finger tip. The ortho doc left the severed piece of bone in there and said it should reattach itself over time. I may never have feeling again in the tip of my finger. It’s been about 10 days now and I just removed the stitches. I finished modifying the saw to make the guard easier to install and remove for blade changes. One thing is for sure now though, I learned a lesson on this one and I won’t do it again. I think the reason it happened is mostly that I think we are all so careful with the work surface or platform of a saw but in this case, the danger was on the return side where I wouldn’t normally think of it as danger. Thanks for reading.
-- "Country Roads, take me home to the place I belong...West Virginia..."
7 replies so far
View amateur's profile
amateur
89 posts in 824 days
#1 posted 766 days ago
Careless idiot? No way! It takes so little to have a terrible accident. I hope you recover fully and swiftly. And thanks for the post, I will be stopping, looking and listening a little more intently in my shop today because of it.
View bubinga's profile
bubinga
867 posts in 834 days
#2 posted 766 days ago
NO band saw I have had ,required me to remove guard on the back of the saw
Do you have to take that off to change the blade ?
If so ,,bad design
-- E J ------- Always Keep a Firm Grip on Your Tool
View Mickey Cassiba's profile
Mickey Cassiba
315 posts in 1198 days
#3 posted 766 days ago
Oww! Always room for another safety post !Hoping your recovery is swift and complete.
-- One of these hammers oughta fix that...
CADguy
5 posts in 766 days
#4 posted 766 days ago
Yeah, the guard has to come off in order to change the blade. What’s worse, you have to walk across the shop and get a Phillips head screwdriver and remove two screws to get it off. I’ve now modified mine by drilling out and tapping the two small screw holes to accept a 1/4-20 threaded stud which I put a little apoxy on before I inserted it. Then I put two small rubber knobs I found at lowes in the specialty drawers on there. Then the knobs ended up being too big to clear both the upper and lower doors(only about a 1/4” of space there which I think is why they used screws) so I fired up the air compressor and proceeded to drill/cut/grind notches in both doors until the knobs could come through them. I didn’t plan on having to do that but once I’d epoxy’d 1/4-20 studs in place I was committed and had to do something to make it work. I agree the initial design could have been better but I bought the thing new for about 250 bucks out the door at a “factory direct tools” outlet over in Foley, AL. That’s the same place I bought my thickness planer (ridgid 13”) for 279. Cant argue with a decent product for an outstanding price, you know?
View jackass's profile
jackass
346 posts in 1879 days
#5 posted 766 days ago
Hi Cadguy,
I once gave my right thumb a real bad cut with a Swiss Army Knife, I was fishing with a bunch of guys among some alder bushes, when I got the hook caught in an Alder for the 0ne millionth time I decided to sit and make a whistle. I cut the appropriate piece and started, well you know the rest. The Doc said I would never feel anything with the side of the thumb again, he was wrong, after about 5 years the feeling started to come back. It’s OK now, I hope you have the same luck. I only needed 5 stitches, lots of blood though. I was concerned watching my life drip away through the end of my thumb, until I got a drive to the Doctor’s office.
Jack
-- Jack Keefe Shediac NB Canada
View gpastor's profile
gpastor
144 posts in 1225 days
#6 posted 766 days ago
What rear guard was that, could you show pics
-- Gray hair is a crown of splendor; it is attained by a righteous life. Proverbs 16:31
CADguy
5 posts in 766 days
#7 posted 766 days ago
I’m at work this morning replying via my iPhone so I cant show you a pic right now. Do a google image search for ridgid bs1400. The guard is a plastic guard that is grey in color and covers the blade while it runs past the power switch on the rear of the saw.
