Rockwell Band saw 28-240
« back to Woodturning forum
Forum topic by pete7170 posted 02-20-2018 03:46 AM 706 views 0 times favorited 23 replies Add to Favorites Watch
View pete7170's profile
pete7170
15 posts in 127 days
02-20-2018 03:46 AM
Topic tags/keywords: rockwell band saw bandsaw
I feel fortunate to have picked up this band saw today. however, I have never owned one and am looking for comments and/or wisdom on what I need to have this be a safe and functional addition to my shop. I know the belt needs to be changed and probably the tires. The only additional item the unit came with is an extra pulley (hanging below the table). Thanks in advance.
23 replies so far
View MrUnix's profile
MrUnix
6768 posts in 2227 days
#1 posted 02-20-2018 04:01 AM
How much you need to do depends on how far you want to take it. Just get it functional, do a restoration to make it like new, or somewhere between the two. At the very least, I’d put new bearings in – both on the wheels and motor. Tires and belt may or may not need to be replaced depending on condition. That extra pulley looks like it was the original one on the motor, as the one on there now doesn’t look right. Seems like you are missing at least the throat insert plate and the table index pin, and the rear blade guard is torn up and probably should be replaced. Original ones were made of wood and are pretty easy to make yourself – or you can probably find a replacement online if you want to throw more money at it. Also, where is the upper blade guides and support rod?
Fortunately, these machines are very easy to work on – so if you decide to do a restoration, it is not very difficult and you will be left with a better than new machine for just a little time and effort.
View TheDane's profile (online now)
TheDane
5448 posts in 3691 days
#2 posted 02-20-2018 07:13 PM
With a little TLC (as Brad described), this saw could be a real gem.
Wish I would have happened onto one of these when I was looking for a saw a few years ago!
View Ted78's profile
Ted78
387 posts in 2028 days
#3 posted 02-20-2018 07:29 PM
“Also, where is the upper blade guides and support rod?” This would be my first concern. If you don’t have it, see if you can find a picture of one online and go back to where/who you purchased it from and ask if they have it. Might just be lying around and someone didn’t realize the two went together. If not you might be able to find parts online. In my experience that path typically doubles how much I paid for the thing, but I like fixing things up and using good quality vintage machinery so I don’t mind too much if it’s not always the most financially wisest path.
-- Ted
View HokieKen's profile (online now)
HokieKen
5284 posts in 1167 days
#4 posted 02-20-2018 08:55 PM
That’s a beautiful saw. I’d go full restoration if it were me ;-)
I think Brad’s right and someone changed the drive pulley at some point. The one hanging appears more original but just figure out which one gives the proper speed for your work. One may have been used to make the saw do double duty for wood and metal.
I would advocate for finding the guard/guides for the top and replacing the back guard as well. If you can source correct parts without exceeding your budget, do that. If you can’t find parts or they’re too pricey, check out some of the many shop-built bandsaws on the web. Particularly Mathais Wendel at woodgears.ca. You can fabricate those parts fairly easily and inexpensively if needed.
As Brad suggests, I would also replace the bearings for the wheels. For me, I wouldn’t do the motor bearings unless needed but it sure wouldn’t hurt. You don’t show the tires but you said you know they need to be replaced. Buy quality tires and balance the wheels after you put the new ones on.
Get an index pin for the table and either buy or make a handful of throat inserts. You may think you only need one but you’ll be happy you have extras when you need them. I got in touch with this guy via eBay and he didn’t have the inserts for my saw but made them for me based on the measurements I sent. Great guy to work with so if you need a source, I recommend him.
Good luck! A nice, well-tuned bandsaw is a pleasure to have in the shop!
-- Kenny, SW VA, Go Hokies!!!
pete7170
#5 posted 02-20-2018 09:34 PM
I’d really like to do a full restoration and have a threat tool at the end. However, I’m not even sure I know what some of the things you guys are recommending are?! Here are some more pics. Thanks a ton for all the comments and wisdom.
HokieKen
#6 posted 02-20-2018 09:43 PM
The busted up piece on the left side that prevents you from accidentally sticking your hand in the running blade… that’s the rear blade guard. You shouldn’t be able to see the blade through it.
See where the blade exits the upper housing? See that “sleeve” on the backside with the thumb screw? There should be a bar that fits in there that has either some bearings or blocks that hug the sides and back of the blade and a shield above the bearings that comes around to… you guessed it… keep you from accidentally sticking your hand into the running blade. :-) Those bearings also prevent blade wander and prevent you from pushing the blade out of line. If you look under the table, there should also be 3 bearings/blocks there. You need those guides in both places or the saw will never perform well at all. The guide is a safety thing. The guides, however, are an absolute necessity.
You’re right. Get new tires.
Throat plate – goes in hole in table around blade.
Index pin – goes in tapered hole on right side of table. Keeps the 2 sections of table aligned and prevents “sagging” over time.
Let’s see some pics of under the table. Of the trunnion and the lower guides and see what kind of shape we’re in there ;-)
MrUnix
#7 posted 02-20-2018 09:49 PM
Here are all the parts you need – so you can tell what you have missing :)
View bigtuna's profile
bigtuna
5 posts in 123 days
#8 posted 02-21-2018 03:29 PM
hey that should clean up nice.
pete7170
#9 posted 02-21-2018 04:31 PM
I will post some pics of the underside of table this afternoon. That picture of all the parts laid out makes me want to put a “For Sale” on the unit. If I can’t find the upper and lower blade guides is that something I would have to have fabricated or are there “aftermarket” versions that would work. I will going back to the shop I got this out of to check around and see if there are parts there. In the mean time I ordered tires 2, inserts 2, blade guard and bearings 2 from replacementsparts.com. My fingers crossed that I can (with help here) pull this thing together.
TheDane
#10 posted 02-21-2018 04:32 PM
Actually, it might make some sense to look for a riser block kit. That would give you some of the missing parts, plus an extra 6” of cutting capacity.
pete7170
#11 posted 02-21-2018 04:42 PM
Thanks for the suggestion. I found this:
Riser Block Kit for Delta 14” Bandsaw with Hex Post Interchanges with Delta 894
Do you know if this should work?
HokieKen
#12 posted 02-21-2018 04:51 PM
Here are the guides. Note that it’s an auction so I don’t know what the actual price will end up being…
Here is the bar that attaches the guides.-
That riser block kit is most likely right but you didn’t link it so I can’t say for sure. Note that with a riser kit, you will get the longer post for the guides but you will still have to source the guides somewhere.
pete7170
#13 posted 02-21-2018 04:56 PM
Sorry, here is the link https://seaurchinforall.firebaseapp.com/Riser-Block-kit-for-Delta-14-Bandsaw-with-hex-post-interchanges-with-Delta-894-.html
I know it states that it works for my model but he is also “selling”, just want to check.
So, if I get the riser kit it allows for the ability to cut lager pieces, together with the guides and the guard and I should be well on my way?
MrUnix
#14 posted 02-21-2018 04:59 PM
Take the table off and post a picture of what is there. No sense in ordering stuff you don’t need. Speaking of ordering stuff – you probably should have held off on ordering bearings, particularly from ereplacementparts.com, unless you are sure of what you have in there now. They used two different bearing sets over the years – early models used the 87xxx series with an extended inner race, while the later models switched to more common 62xx series. You would need 4 bearings in total, two for the upper wheel, and two for the lower. Ordering them through ereplacements (or any of the aftermarket suppliers) cost you a lot more for questionable quality – best to get them through a real bearing supplier like Accurate Bearing – better bearings for significantly less.
As for what is missing – all of the parts you need are out there. They made these saws for over 50 years and remained basically unchanged over those years, so the parts are all mostly interchangeable between years/decades. Figure out what you need, then go from there.
Regarding the riser kit – that won’t get you the guide assembly, just a longer hex rod and a couple of longer blade guards. You already have a rear guard to use as a pattern to make a new one, and you can get the hex support rod fairly cheap at a local metal supplier or on-line; there isn’t anything really special about it.
HokieKen
#15 posted 02-21-2018 08:19 PM
- pete7170
The riser will give you an additional 6” resaw capacity. It’s nice to have IMO. It also means you need longer blades so consider that. Just to be clear, the riser kit does NOT include the guides. Only the longer hex rod for the guides and a longer guard to cover the additional blade. You’ll still need to source the guide piece that has the blocks/bushings.
