Hook & Loop for Drum Sander
Forum topic by wncguy posted 02-19-2018 06:41 PM 296 views 0 times favorited 7 replies Add to Favorites Watch
View wncguy's profile
wncguy
395 posts in 2337 days
02-19-2018 06:41 PM
Topic tags/keywords: sander question
I have the Grizzly G0716 drum sander & while it’s more for light duty, it works fine for me… except I dread having to change the sand paper. I find it really difficult to get the last of the roll into the tension slot/clamp.
While Grizzly has a hook & loop conversion for some of larger drum sanders, nothing for this one.
Has anyone found a conversion “kit” for this unit? I’d sure appreciate any info/advice.
Thanks!
-- Any man can be a father, but it takes someone special to be a Dad
7 replies so far
View Kelly's profile
Kelly
2039 posts in 2969 days
#1 posted 02-19-2018 07:56 PM
Look around the SandMaster web site and see if their kits would work.
wncguy
#2 posted 02-20-2018 02:00 PM
Kelly, I checked the site out but for some reason I could not find way to search for info. The site I was checking is in the UK, was that the one you suggest?
Thanks.
Kelly
#3 posted 02-20-2018 06:26 PM
Kelly
#4 posted 02-20-2018 06:41 PM
Here’s another link for those pages, which might have more choices:
http://stockroomsupply.ca/shop/sandpaper-rolls.html
Keep in mind these are used on the Sandmaster and their claim to fame is, the centrifugal force lifts the hook & loop, thus the paper, off the drum a little leaving an air gap. This means cooler running so longer lasting paper.
The down side would seem to be you MUST keep moving or suffer snipe, because of the expansion.
wncguy
#5 posted 02-21-2018 01:10 PM
Thanks Kelly, I really appreciate your help/input. After looking at the info, not sure that would work for me on my sander.
View rwe2156's profile
rwe2156
2964 posts in 1506 days
#6 posted 02-21-2018 01:43 PM
Yeah, you definitely don’t want to use adhesive sandpaper.
I’ll bet you the conversion kit would work on yours. Its really just a matter of putting the hook tape on the drum.
BTW I did this on mine and I think the paper retains more heat because now I get burn marks on light colored wood which I never did before. Something to consider.
wncguy
#7 posted 02-21-2018 03:51 PM
rwe2156 – appreciate your input… as noted I am using the Grizzly G0716, what sander are you using?
