How can I drill through metal with a drill?
Forum topic by EricWrights posted 04-13-2011 03:58 AM 8835 views 1 time favorited 5 replies Add to Favorites Watch
View EricWrights's profile
EricWrights
94 posts in 3120 days
04-13-2011 03:58 AM
Topic tags/keywords: drill metal
Do I need a special metal drilling bit or do I have to have a completely different tool?
I want to drill through a small piece of metal that is about 4mm thick to that I can lock my garden gate.
-- Sawing, sanding, scraping, cutting? Let Rockwell Sonicrafter do the job. http://rockwellsonicrafter.com & A more general blog at http://resay.org
5 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2559 days
#1 posted 04-13-2011 04:01 AM
Use a sharp bit at slow speed and you should do fine.A drill press makes metal drilling much easier but may not work in your situation.Hope this helps.
View Jack_T's profile
Jack_T
623 posts in 2900 days
#2 posted 04-13-2011 04:05 AM
You should also use a lubricant to keep the bit cooler.
-- Jack T, John 3:16 "For God so loved the world that he gave his only Son, so that everyone who believes in him might not perish but might have eternal life."
View whit's profile
whit
246 posts in 3846 days
#3 posted 04-13-2011 04:27 AM
You might also want to start with a smaller bit (.125) and work your way up to a larger size – depending on how large you need to drill. It’s a lot easier on the bits. If the metal isn’t attached to anything (like the gate or a post) make sure you have it well secured before you drill it; it will bite just as the bit breaks through the far side of the hole.
Whit
-- Even if to be nothing more than a bad example, everything serves a purpose. cippotus
TopamaxSurvivor
18157 posts in 3545 days
#4 posted 04-13-2011 07:32 AM
Like they say above use HSS drill, not black oxide or coated drill. If it is tough going, keep center punching the hole until you get through.
View Jim Finn's profile
Jim Finn
2591 posts in 2791 days
#5 posted 04-13-2011 10:20 PM
When drilling in metal keep the speed down and the pressure up. (A drill press helps with this) There should be large chips generated not fine powder when drilling.
