Cantilevered Shelving for Storage Containers
Forum topic by devann posted 04-13-2011 02:39 AM 8557 views 5 times favorited 10 replies Add to Favorites Watch
View devann's profile
devann
2246 posts in 2562 days
04-13-2011 02:39 AM
Topic tags/keywords: resource tip pine drill press skilsaw
In need of some shelving for material storage I came up with this design to use in a storage container. I wanted an open front without legs for easier access to the material stored. And I wanted some kind of adjustable design. Please If I could, I’d like to have your 2¢ about how to do a better job of it.
Here are the brackets. Made from plywood glued and fastened to the 2×4s
Here is the leg to support the brackets. Holes are 1/2”—3” o.c.
This is the notch cut in the top of the leg. I used a t-nut to keep the leg from splitting and bumped up to a higher grade bolt. This is what keeps the shelf from crashing down. The legs are spaced at the tie down locations along the top and bottom of the container walls.
Here is an example of the leg with a shelf bracket
Here I have the legs and brackets assembled. The top shelf is 30”, the two in the center are 24” and the bottom shelf is 18”
Here I have it finished. I used 3/4 plywood for the shelves. It’s been up for about a week now so far so good. Yep, you guessed it, now I gotta do the other side.
Update: Well the other side is done and the shelves have been up for 3 months now without any sagging or deflection so I guess they’ll work out as planned.
10 replies so far
13594 posts in 3211 days
#1 posted 04-13-2011 02:57 AM
i was going to tell you how to do it a different way
but buy the time i got to the end of the article
i realized you were almost done
and decided to keep quiet
i mean why have you tear all this out
and burn it
i threw it back in the pond
you should have seen it
the grain and textures
popped right out
with the 8 coats of rubbed french finish
oh well
this came out nice
you should be proud
nice and sturdy too
devann
#2 posted 04-13-2011 04:01 AM
Thanks David, I still have to do the other side you know. and I have another 40’ container.
View wseand's profile
wseand
2796 posts in 2911 days
#3 posted 04-13-2011 04:58 AM
The only thing I would have done different is build it in my shop. Very well done, I might have to steal the idea.
View spunwood's profile
spunwood
1198 posts in 2706 days
#4 posted 04-13-2011 05:12 AM
Well said wseand!
-- I came, I was conquered, I was born again. ἵνα ὦσιν ἓν
spunwood
#5 posted 04-13-2011 05:12 AM
I would have used that design but my walls are bricko-block
View Tag84's profile
Tag84
573 posts in 2526 days
#6 posted 04-13-2011 11:02 AM
Looks great and sturdy Darrel! you can put it up quikely and it’s adjustable? great :)
-- -Thomas -
View tenontim's profile
tenontim
2131 posts in 3614 days
#7 posted 04-13-2011 01:38 PM
I have one of these containers in the 20’ size, that I store my lumber and etc in. I have the steel adjustable shelving on each side, but I need some deeper shelves on the end. I think this design will fit the bill. I hadn’t thought about making a lot of shelves, until I saw this. Looks nice and sturdy. Thanks for the post.
View blackcherry's profile
blackcherry
3336 posts in 3693 days
#8 posted 04-13-2011 01:56 PM
Wow plenty of hard work on this storage unit, but well worth the effort in the long run. Lumber storage can get out of hand in a hurry , but you have this under control enjoy and thanks for posting …BC
View LittlePaw's profile
LittlePaw
1571 posts in 2948 days
#9 posted 04-14-2011 03:43 AM
Nice and neat now. I need to build one like it . . . mind if I copy your design?
-- LittlePAW - The sweetest sound in my shop, next to Mozart, is what a hand plane makes slicing a ribbon.
devann
#10 posted 04-14-2011 07:11 AM
Thanks for the kind comments y’all. I figure anything posted on the site is there for the taking, I least anything I post is. Knock youselves out.
