Mahagony and cherry tabletop
Forum topic by WalkerTexasRanger posted 02-18-2018 10:25 PM 531 views 0 times favorited 9 replies Add to Favorites Watch
View WalkerTexasRanger's profile
WalkerTexasRanger
29 posts in 1414 days
02-18-2018 10:25 PM
I just finished a dining tabletop. The top is made from 2” alternating slats of African mahogany and cherry surrounded by amahogany 4” band. I want to keep it as light as possible. I tried danish oil and tung oil but it leaves the wood darker than I would like. Any suggestions for finishing and keeping this top lighter. Also, I have some very slight imperfections on my end joints where I joined the 2” slats to a solid mahogany end piece. Any suggestions on products to fill these cracks..
9 replies so far
View Lazyman's profile
Lazyman
2386 posts in 1503 days
#1 posted 02-18-2018 10:37 PM
Any finish is going to darken it. Water based polyurethane probably yields the least darkening effect in my experience but can leave the wood looking a little like it is coated in plastic if applied too thick. It will be more durable than Danish or tung oil on a table top. A blonde shellac would probably be the next but is probably not durable enough for a dining table.
View bbasiaga's profile
bbasiaga
1240 posts in 2111 days
#2 posted 02-18-2018 10:38 PM
Clear shellac will add a light yellow tint. Something like General Finishes High Performance water based top coat is perfectly clear, or at least as close to perfectly clear as possible.
Brian
View WyattCo's profile
WyattCo
93 posts in 220 days
#3 posted 02-18-2018 11:01 PM
Brushing lacquer.
View CaptainKlutz's profile
CaptainKlutz
447 posts in 1610 days
#4 posted 02-18-2018 11:09 PM
Any oil will darken the wood.
Most varnish/poly will darken wood, but only slightly due yellow tone added.
Blonde Shellac is least color adding among typical finishes.
Only finish that will not add any color to wood is called a water-white finish, and the list of types is very short.
Included are a few catalyzed spray on lacquers and/or some water based acrylic/poly blends. Since typical varnish/shellac/lacquer wood finish always adds some (yellow) tone to wood, many “off-the-shelf” water based finishes add similar tones making “water-white” harder to find. Best source for durable dining table “water white” finish would be an industrial paint supply house that sells to cabinet shops. Most likely require a spray on finish.
PS – Your cherry wood is going to darken naturally and will make it hard to keep the original look of the wood top over time, even with a water-white finish? Be really curious to see pictures when new and as it ages.
Best Luck.
View caboxmaker's profile
caboxmaker
281 posts in 504 days
#5 posted 02-19-2018 01:13 AM
Looking forward to seeing the table.
View Jeff Bremer's profile
Jeff Bremer
14 posts in 212 days
#6 posted 02-21-2018 06:18 AM
To fill the cracks, take some sanding dust and mix it with a small amount of shellac until you have the consistency of putty. Press the putty into the crack and let it dry (won’t take long), then sand. You may need to do more than one application.
A warning though, the putty will stain darker than the wood, so if the crack is in a very visible spot, you might want to experiment with sanding dust from a lighter wood.
I recently read, but haven’t tried yet, that sanding immediately after pressing the putty into the crack will help match the color to the stained wood.
Good luck!
View JP4LSU's profile
JP4LSU
83 posts in 263 days
#7 posted 02-21-2018 01:02 PM
Brian
- bbasiaga
+1 on General Finishes. I used a water based exterior finish on a front door that I stripped the stain off of. It didn’t darken the wood at all and if there are repairs needed, just sand it a little and put another coat on.
I’m really liking the finish on the door. If I’m not using a Danish or Tung oil on a piece I would consider these products.
-JP
View bondogaposis's profile
bondogaposis
4925 posts in 2467 days
#8 posted 02-21-2018 02:00 PM
Both cherry and mahogany will darken over time as their natural patina develops, so I think your efforts to keep it light will be futile. In that sense I don’t think it matters what type of finish you use.
-- Bondo Gaposis
View sras's profile
sras
4871 posts in 3245 days
#9 posted 02-21-2018 02:25 PM
If you want to keep the wood in the original color the best solution I know of is a high end marine finish. It is a 2 part linear polyurethane. Perfectly clear and the highest UV blocking rating I have seen. The UV blocking slows the natural darkening of woods like cherry & mahogany. Downside – it’s expensive!
