2X2 table legs
Forum topic by Jerry Spencer posted 04-12-2011 04:39 PM 5424 views 0 times favorited 8 replies Add to Favorites Watch
View Jerry Spencer's profile
Jerry Spencer
111 posts in 2778 days
04-12-2011 04:39 PM
I have a set of plans for a coffee table in which they make the 2X2 legs by riping 1X6’s at a 45 degree angle and gluing the four sides together. Has anyone tried this method and is it worth the extra work? An 8ft. 1X6 red oak is $14 and the 2X2s are $19 at my local mill. If I make the coffee and two end tables it would be a savings of $15 to put towards another tool!!
-- Jerry - Ohio
8 replies so far
16274 posts in 4183 days
#1 posted 04-12-2011 04:57 PM
I think the main reason for creating legs with the 4 mitered sides would be because you didn’t have access to the thicker material. If you can get the 2×2 for legs, it would save a whole lot of trouble.
As far as saving money, I don’t see where using the 1×6 will save you anything. Assuming you want the legs to be 1.5” square, you can’t get all four sides out of a 1×6… you’d have to move up to a 1×8 at least.
EDIT: Okay, after putting it down on paper, I suppose you could get it out of a 1×6. Sure doesn’t seem worth the trouble, though.
View ddockstader's profile
ddockstader
155 posts in 3226 days
#2 posted 04-12-2011 05:26 PM
Where this really makes sense is if you are working with quarter-sawn oak. Using this method, the flecks and rays will show up on all 4 sides. For flat-sawn oak there is no similar advantage.
View Nomad62's profile
Nomad62
726 posts in 2922 days
#3 posted 04-12-2011 05:45 PM
I’m thinking the cosmetics would be the first reason to do such a thing, but maybe they would tend to stay straight more than a solid leg? Not sure… there are a hundred ways to do anything, who’s “right”? I say do it the way you want it done unless someone else is paying you to do it as planned.
View ooootis's profile
ooootis
35 posts in 2590 days
#4 posted 04-12-2011 05:47 PM
1+ on what the ddockstader said. Make them a bit larger in case the glue up doesn’t go just right, then trim to the desired measurements if needed. Actually I would practice the clamping (dry) a few time just to get the hang of it, but once the glue hits it that’s a whole nother story.
Jerry Spencer
#5 posted 04-12-2011 06:41 PM
Thanks for the feed back, I’m inclined to stay with the solid stock after hearing from you guys,
Thanks again, I love this site for this kind of help.
-- Jerry - Ohio
View Bertha's profile
Bertha
13521 posts in 2657 days
#6 posted 04-12-2011 06:46 PM
I laminated legs on a recent project because I didn’t have access to the stock. It ended up being a real chore and I wasn’t terribly happy with the results. If this is a project you’ll treasure, you won’t miss the few extra bucks and it’ll get completed sooner!
View Howie's profile
Howie
2656 posts in 2887 days
#7 posted 04-12-2011 07:25 PM
I think Charlie and Nomad nailed it. For 15 bucks is your time worth it?(4/15=3.75 ea not much for the time involved)
-- Life is good.
View HerbC's profile (online now)
HerbC
1743 posts in 2824 days
#8 posted 04-12-2011 08:25 PM
Howie,
Just a nit-pick but 4/15 = 0.266666666666666… whereas 15/4 = 3.75.
But your point is valid one the problem is stated correctly.
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
