I love my push pad
Forum topic by lanwater posted 04-12-2011 07:45 AM 2009 views 0 times favorited 12 replies Add to Favorites Watch
View lanwater's profile
lanwater
3111 posts in 3170 days
04-12-2011 07:45 AM
I needed to cut an insert for my dado blade.
I stacked 2 pieces of leftover plywood and secure them over the tablesaw with a couple of hold down.
Since that’s the first time I use the hold down in that fashion, I decided to push from the top.
The thought of just pressing with my hand while raising the dado blade definitely crossed my mind since I wanted to raise the blade by 3/4” only. I decided to do it right and use a push pad.
While raising the blade, I was looking at the front where the height is lower than the blade top that I was not seeing.
I am glad I used a push pad…
-- Abbas, Castro Valley, CA
12 replies so far
13641 posts in 3577 days
#1 posted 04-12-2011 08:21 AM
physics
psychics
karma
and
luck
aren’t you glad
you looked for a train
before crossing
the tracks
lanwater
#2 posted 04-12-2011 08:42 AM
That rimes David. I am so glad I did.
Skarp: I am also making a point of using them on the router table whenever possible.
#3 posted 04-12-2011 08:47 AM
it’s also the name of a law firm
for woodworkers that don’t
stop
look
and
listen
View plantek's profile
plantek
312 posts in 3035 days
#4 posted 04-12-2011 04:08 PM
Good call.
-- If you want it and it's within reason... It's on it's way!
View mafe's profile
mafe
11771 posts in 3325 days
#5 posted 04-12-2011 05:51 PM
Wauuuuu I’m sure glad also! I would have hated to hear the alternative.
Best thoughts,
Mads
lanwater
#6 posted 04-12-2011 07:06 PM
David: I like that name. That law firm must be poor because we tend to ignore “stop, look and listen”.
Plantek: It’s one of those moments where one think of cutting corners to go faster.
Mafe: Jim Vice, My teacher, taught me to stop and slow down from time to time. He always say: “Think about your are about to do. If it is not completely safe, don’t do it”.
View degoose's profile
degoose
7245 posts in 3590 days
#7 posted 04-12-2011 08:21 PM
Play safe.
lanwater
#8 posted 04-12-2011 09:09 PM
Larry: Safety is not my nickname but I try. Everytime my fingers are getting to close to a spinning blade or bit, I usually try to find a better way.
View tdv's profile
tdv
1196 posts in 3306 days
#9 posted 04-12-2011 09:25 PM
I speak from real experience my back gave way while pushing a panel through my tablesaw (Disc problem) & I collapsed pushing my hand through the blade not even a guard would have saved me ‘cos my hand took the same path as the panel & I lost my middle two fingers at the halfway mark, believe me they don’t grow back!
I never felt a thing at the time, but I’ve felt a lot since & although I still get round what I need to do it’s a lot better the way God made us (with a full compliment of digits) your pad did a good job frame it in your shop so you never forget
Be safe & my best
Trevor
-- God created wood that we may create. Trevor East Yorkshire UK
lanwater
#10 posted 04-12-2011 10:42 PM
Trevor: My dad lost 2 digits.
one when trying to cut a sheet of plywood, on a table saw he made himself, without any help. To this day he is still not clear on how his hand ended on that blade.
The second was lost because of one of his grand kids rush into the shop to hide behind grandpa because a couple of kids were chasing him. Well he got pushed forward during a cut.
This said, you scared me since I too have discs. Not too bad yet.
View tdv's profile
tdv
#11 posted 04-12-2011 11:12 PM
Wow! Ian,I bet that was one traumatised grandson, I think sheet goods are the worst especially thin sheets having the blade set low they often bend under their own weight & arch in the middle (good case for an outfeed table)so the blade has to be set higher & you need a hand on them to hold them flat it’s a dangerous scenario so now I cut all sheets with a track & circular saw into manageable size pieces (for me 3’ x 2’ max) then to the table saw. If I’m having a bad day with my back I do something else preferably with a hand plane ;-)
Best
Trevor
lanwater
#12 posted 04-12-2011 11:36 PM
One of my nephews. He remembers when he see it.
I too use a circular saw to do a rough cut before taking it to my tablesaw. Sometime I have the homecenter do the rough cut + 2” since their blade is awfull.
My dad build his own tablesaw by using a circular saw under the table. Of course no height adjustment. No adjustment of any kind.
When I see him in the summer he never let me touch any of his power tools. I always wonder why.
