need help with chair leg
Forum topic by JHarshaw posted 02-17-2018 10:44 AM 445 views 0 times favorited 6 replies Add to Favorites Watch
View JHarshaw's profile
JHarshaw
8 posts in 2049 days
02-17-2018 10:44 AM
Topic tags/keywords: question
Hello all,
Relatively new to woodwork, long time lurker on the site, and could use your sage advice. I am duplicating a chair leg but cannot figure out how best to duplicate this element- the carved decorative circle.
Any process besides free-handing?
Thanks for any ideas.
View WoodshopTherapy's profile
WoodshopTherapy
27 posts in 340 days
#1 posted 02-17-2018 11:37 AM
Nothing off the shelf that I know of. What you’re looking for is something like a forcetner bit, which is used to cut flat bottom holes, but you need a hollow ground bit to get the curve you’re looking for. There are rosette drill bits which make round decorative holes, so maybe if you search that term you might find something.
I doubt this would have been carved by hand. It looks like a manufactured piece.
Regards,
Scott
-- Scott Bennett - sharing woodworking knowledge at Home Improvement Woodworking
View cabmaker's profile
cabmaker
1744 posts in 3044 days
#2 posted 02-17-2018 01:39 PM
rosette cutter on the drill press
Ofcoarse the radius needs to be pretty close
just watch the depth
cutter wlth a full button…...not a button and ring,,,,,(If your near me you can use mine )
runswithscissors
2924 posts in 2261 days
#3 posted 02-18-2018 12:42 AM
Grizzly has rosette cutters, though I don’t see one that looks exactly like your profile.
View Loren's profile
10477 posts in 3883 days
#4 posted 02-18-2018 12:52 AM
A rosette cutter was probably how it was
done. Good luck finding one that matches
at a reasonable price.
The issue could be worked around by drilling
a hole with a fortsner bit and turning a domed
plug to fit the hole.
You could make your own cutter by regrinding
a spade bit. It sounds crazy but it’s the first
thing I would try personally. I might cut off
the shank of the bit real short to reduce chatter.
JHarshaw
#5 posted 02-18-2018 05:38 PM
Thanks for the ideas, folks! I haven’t found a cutter like this type of pattern, so I will resort to asking the wife how important this look is to her!
I appreciate the responses- cheers!
View Ripper70's profile
Ripper70
1191 posts in 1144 days
#6 posted 02-18-2018 05:42 PM
Find a cutter that’s close but even slightly larger and then recut all the legs to match.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
