The Wardrobe Closet - how do I "fix" this.
« back to Joinery forum
Forum topic by David Schwarz posted 02-17-2018 05:16 AM 2614 views 0 times favorited 34 replies Add to Favorites Watch
View David Schwarz's profile
David Schwarz
100 posts in 339 days
02-17-2018 05:16 AM
With machine restoration (temporarily) behind me, I’ve turned my attention to THE wardrobe closet. To be honest, probably far more chosen to chew than I was ready to bite. But now here I am and forward I must go. My intention with this post is to only ask two questions – I’ll try to save the epic journey for the more appropriate blog.
So the beginning seems humble enough – build a set of three modular drawer frames, with three drawers per frame – and nine drawers total if my elementary schooling remains intact. Here is/was the SketchUp virtual model that got this all started:
And from that model I now have this:
Question number one – so that I can now be more conversational in my woodworking wanderings, I would be grateful if someone could share with me how to refer to the various components highlighted by the four colored arrows.
With that little bit behind us, I present question number two and the primary focus of this post. I used a combination of sliding dovetails and box joints to assemble everything. My joints are satisfactory, but not perfect, with dovetails overhanging where they will need to be flush – the same being true for some of the box joints. Here ’s an up close and personal of the aforementioned victims:
My question then is what the best method will be to make everything on the face flush. The drawers will be inset walnut faces, so I want to show off these joints – desire obviously exceeding my current skill level.
So, do I sand by hand, with a dedicated machine (and what might that machine be), or do I use a hand planer (scared to death of this option – bad childhood memories litter the road traveled by a hand planer). Seriously though, any combination of the above (or other) are fine – I’m simply seeking the advice of those more knowledgeable that have traveled these roads before me.
Thanks in advance for your help :-)
David
-- I make trees cry.
34 replies so far
View jonah's profile
jonah
1839 posts in 3420 days
#1 posted 02-17-2018 05:23 AM
You can easily sand those flush with a random orbital sander. Start with 80 or 100 grit and work up to 150-180.
View Loren's profile
10477 posts in 3769 days
#2 posted 02-17-2018 05:29 AM
View Woodknack's profile
Woodknack
12341 posts in 2501 days
#3 posted 02-17-2018 06:10 AM
- David Schwarz
This will be interesting, I bet you get a lot of different answers. Never having seen anything built this way, I checked Illustrated cabinetmaking and there was nothing helpful there so I went with my first impression. The purple I would call a rail because it’s roughly equivalent to a dresser rail. Green = stile or post because it’s a vertical support piece. Blue, an apron if a top is attached or a stretcher if none. Red = header. There may be architectural terms that are a better fit.
#4 posted 02-17-2018 06:21 AM
Your construction methods are unorthodox
in that traditional casework wasn’t made
as skeleton frames because it had the purpose
of keeping stuff like dust and vermin out.
In any case, the frame under a drawer is called
a web frame. Again yours are unorthodox
because you’ll presumably be using drawer
slides. Sometimes thin dust panels are fitted
in the web frame. I suppose they kept dust
from sifting down onto costly linens in lower
drawers.
David Schwarz
#5 posted 02-17-2018 03:12 PM
in that traditional casework wasn t made
- Loren
Sorry Loren – this is always the risk one takes when posting without all the details. Here is an earlier rendition of what everything will look like assembled:
This project is to be constructed primarily from maple and walnut. The design (I claim all responsibility for it’s unorthodox nature) is my attempt to be as efficient as possible with the wood purchased. When all is said and done, nothing will be “open” to the elements. At least that’s the plan.
David
David Schwarz
#6 posted 02-17-2018 03:17 PM
- jonah
Thanks Jonah. My fear with any sanding approach is rounding edges where I want to maintain perfect 90 degree angles. The secondary concern is losing my flat surfaces as I sand. Your skills are likely more refined than mine – I still struggle to keep everything on a linear plane when I break out sand paper. Seems I’m always taking more off the outer edges of any project I tackle. That’s what compelled me to consider a hand planer.
David
View Lazyman's profile
Lazyman
2399 posts in 1509 days
#7 posted 02-17-2018 03:22 PM
You could use hand planes to make everything flush. For the dovetailed horizontal pieces, probably would have been easier before assembly or make the dovetail groove a little deeper so it is flush. You could use a chisel for the box joints. Another option is a belt sander.
View bondogaposis's profile
bondogaposis
4931 posts in 2473 days
#8 posted 02-17-2018 03:27 PM
I would make those joints flush with a block plane. As far as terminology goes, the verticals are stiles and the horizontals are rails. I’m going to call the the front to back member, the blue arrow, a stretcher.
-- Bondo Gaposis
David Schwarz
#9 posted 02-17-2018 03:27 PM
Probably would have been easier before assembly or make the dovetail groove a little deeper so it is flush.
- Lazyman
Couldn’t agree more. The backstory is long but the short version is that everything was more or less flush during dry fitting, but some of the sliding dovetails were too tight and hindsight on the best way to keep things flush – rather too late :-(
David
David Schwarz
#10 posted 02-17-2018 03:31 PM
- bondogaposis
Do you have any recommendations perhaps regarding manufacturer and model? I gravitate towards well built – preferably in the US. I’m not a xenophobe, but I’ve had enough Chinese manufactured products to know that those are best reserved for projects where there will be limited use to solve an immediate problem.
I won’t say that money isn’t an issue, but I do understand that you get what you pay for.
David
View Hermit's profile
Hermit
189 posts in 1446 days
#11 posted 02-17-2018 03:33 PM
I’m no expert but couldn’t you tack or clamp scrap pieces on top and or bottom to support the random orbital? Seems like it would work to me so you wouldn’t get the roundover.
-- I'm like the farmer's duck. If it don't rain, I'll walk.
David Schwarz
#12 posted 02-17-2018 03:44 PM
I m no expert but couldn t you tack or clamp scrap pieces on top and or bottom to support the random orbital? Seems like it would work to me so you wouldn t get the roundover.
- Hermit
I think that’s a fantastic idea! I had a similar thought for the planer, but hadn’t considered the approach for a sander. Wondering if anyone else has ever tried to do this? As a concept, seems it should work – as long as you can keep the reference material locked in place.
David
View splintergroup's profile
splintergroup
2253 posts in 1344 days
#13 posted 02-17-2018 04:00 PM
You could take a similar approach with the scrap pieces and use a router with a bushing (just a thought)
View jbay's profile
jbay
2604 posts in 1020 days
#14 posted 02-17-2018 04:05 PM
If your not good with a hand plane, then I would use a sanding block and some manual labor.
I would use a 100 grit sanding belt wrapped tight around a block of wood.
#15 posted 02-17-2018 04:07 PM
- Loren
This project is to be constructed primarily from maple and walnut. The design (I claim all responsibility for it s unorthodox nature) is my attempt to be as efficient as possible with the wood purchased. When all is said and done, nothing will be “open” to the elements. At least that s the plan.
David
- David Schwarz
I didn’t mean to scold you. I think it’s cool. It’s
just built in such a way that naming the parts
is a little challenging.
showing 1 through 15 of 34 replies
