glue block question
« back to Woodturning forum
Forum topic by Karda posted 02-16-2018 10:05 PM 360 views 0 times favorited 2 replies Add to Favorites Watch
View Karda's profile
Karda
1314 posts in 752 days
02-16-2018 10:05 PM
I want to return a couple small bowls i did, I will use hot glue. how much glue contact do I need will a half inch or so be sufficient or do i need full bottom coverage. The work will be mostly finish work and sanding thanks
2 replies so far
View walnutles's profile
walnutles
13 posts in 395 days
#1 posted 02-17-2018 07:41 AM
I glue all around the rim if I’m sanding the base or removing the chucking point as it makes removing the glue easyier to remove and for the inside of the bowl and the edge of the bowl I use different sized plate shapes of wood to fit different sized bowls that have a chucking points on them and that I can glue to the base of the bowl.
https://s3.amazonaws.com/vs-lumberjocks.com/p4aaoqd.jpg!
I found that if you put a dollop of hot melt glue on the base of your bowl and stick it to some wood its a nightmare to get the bowl off and the glue off. Les
Karda
#2 posted 02-17-2018 09:57 PM
ok thanks
