Water Heater - Box in or ignore?
Forum topic by londonlad posted 02-16-2018 04:45 PM 534 views 0 times favorited 8 replies Add to Favorites Watch
View londonlad's profile
londonlad
7 posts in 3393 days
02-16-2018 04:45 PM
I’ve had a water heater in my existing shop for 20 years – no problems.
I’m moving to a new place with a pristine & huge basement! It has a water heater in one corner.
Should I box that heater in or just leave it?
Would appreciate opinions.
Londonlad
8 replies so far
5173 posts in 2692 days
#1 posted 02-16-2018 05:47 PM
If it’s gas fine dust may settle on parts that don’t want fine dust on them, but otherwise I wouldn’t worry about it (personally). I also wouldn’t spray lacquer down there…..but that’s about it.
View John Smith's profile
John Smith
1481 posts in 361 days
#2 posted 02-16-2018 06:15 PM
is the WH gas or electric ?
-- I started out with nothing in life ~ and still have most of it left.
View EarlS's profile
EarlS
1899 posts in 2547 days
#3 posted 02-16-2018 06:21 PM
Keep in mind that you will have to replace the water heater some day.
View bonesbr549's profile
bonesbr549
1576 posts in 3266 days
#4 posted 02-16-2018 07:01 PM
If gas …no, if electric keep it accessable. Mine are in my basement, and don’t think about it, but mine are gas.
View Hermit's profile
Hermit
210 posts in 1524 days
#5 posted 02-16-2018 08:30 PM
If gas, you can enclose it remembering to leave enough room (a door big enough and not to small that it ticks off the installer) for when it has to be replaced. If gas and you enclose it, you will need to install combustion air venting in the top and bottom of the enclosure.
Electric doesn’t require combustion air venting and can also be enclosed, remembering to leave enough room to replace it when the time comes.
It’s your call if you want to enclose it. Alot of the newer gas water heaters all have sealed burner chambers.
-- I'm like the farmer's duck. If it don't rain, I'll walk.
View caboxmaker's profile
caboxmaker
281 posts in 587 days
#6 posted 02-16-2018 08:34 PM
If you enclose it you’ll have two small walls to hang things on.
View Andybb's profile
Andybb
1489 posts in 802 days
#7 posted 02-16-2018 08:57 PM
- EarlS
Otherwise, I wouldn’t worry about it.
-- Andy - Seattle USA
View woodworm1962's profile
woodworm1962
145 posts in 299 days
#8 posted 02-16-2018 09:05 PM
Try this
-- No one likes the truth...
