feather board use with TS
Forum topic by descout posted 768 days ago 698 views 0 times favorited 4 replies Add to Favorites Watch
View descout's profile
descout
104 posts in 1260 days
768 days ago
I am aware that on a table saw you want to position the feather board BEFORE the blade when doing a standard rip cut so that no binding occurs behind the blade. But with my dado blade inserted and I am performing a dado cut in the side of a stiles and rails (to accept a raised panel for a door). Could I position the featherboard directly ACCROSS from the blade to help hold the piece firmly against the fence since it is not a through cut?
View rance's profile
rance
3855 posts in 1326 days
#1 posted 768 days ago
Yes, that is the standard practice. And especially with dados, it is also beneficial to have another one holding the workpiece firmly down to the table.
View drewnahant's profile
drewnahant
218 posts in 1255 days
#2 posted 768 days ago
Agreed, though, I find it better to put the feather board across from the front of the blade, especially if you are doing long pieces, to be sure the stock is square against the fence before as the cut starts. I once had to dado a long piece about 7 feet long, and was not set up properly, stood about 2 feet from the saw so I could easily balance the board, because I didnt have a hand pressing it agianst the fence, I was just watching it make contact with the fence, when it finally got to the featherboard, it slid over the 1/32, 1/16 whatever, and kicked back pretty bad.
If you are pressing it firmly against the fence when you start, it shouldnt be an issue. Of course, if you dont let you hand slip you should never need a push block either, but none of us are dumb enough to assume that.
14844 posts in 2384 days
#3 posted 768 days ago
I would agree that there is nothing wrong with having a featherboard directly across from the blade when doing a non-through dado cut, but I don’t see much point in it either.
The main thing I want my featherboard to do is ensure that my board is properly against the fence when it contacts the blade. This is true no matter whether it is a through cut or not. For that reason, I still position my featherboard before the blade. I’m not really seeing what the advantage would be of putting it next to the blade instead.
View dbhost's profile
dbhost
4748 posts in 1398 days
#4 posted 768 days ago
I tend to agree with CharlieM1958, The whole point is to hold the stock tight up the fence just prior to it contacting the blade, not a whole lot of point shoving it sideways as it comes across the blade.
