| Forum topic by bues0022 | posted 771 days ago | 1380 views | 0 times favorited | 14 replies | ![]() |
771 days ago |
I few months ago I posted this project: http://lumberjocks.com/projects/41574 They are bottle openers, and the one with the spalted top has magnets imbedded in the walnut layer. It is finished with paste wax. Now, when you put it on the fridge, the wood is too smooth and it slides right down – despite the magnets having enough force to hold it (just not vertically because of the low friction). In an attempt to fix it without causing significant visual problems, I made some small silicone “bumpers” and attached them to the front. While this is better, with repeated open/close cycles of the fridge, it still falls down. The only thing that seems to work right now is to put the top silicone bumpers above a different magnet so it’ll stay put. Question for you all: How can I make thes bottle openers stay on the fridge without causing significant visual defects? I thought about finishing the outside with something other than wax, but if I dipped in silicone, that layer would eventually peel, and look terrible. Any other thoughts? I want it as inconspicuous as possible. -- Ryan -- Maple Grove, MN |
14 replies so far
#1 posted 771 days ago |
The only thing I can think of is to use a stronger magnet. Some of these more modern magnets are exceptionally strong. -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#2 posted 771 days ago |
I agree with Bertha…the magnet here is not strong enough…..or you might want to imbed a second magnet to keep the opener from turning and sliding. You can make texture (like fluting the handle) for a “grip” which might create enough friction to slow the sliding. You could imbed a small piece of sand paper or add some sand to glue and make some small inlays to slow it down…..There are alot of ways to do this….just depends on what you want to have the finished project to appear. -- Woodworking.....My small slice of heaven! |
#3 posted 771 days ago |
sounds like magnets is it you might take some 60grit paper to the door -- david - only thru kindness can this world be whole . If we don't succeed we run the risk of failure. Dan Quayle |
#4 posted 771 days ago |
Stronger magnets… -- Manufacturer of fine quality sawdust since 1984. Comments and advice on my shop welcome. Check it out at http://lumberjocks.com/dbhost/workshop. Gladly accepting shop build donations! |
#5 posted 771 days ago |
I was thinking about stronger magnets, but that doesn’t help much for the two I’ve already made :( I got them at the craft store, and there are 6, 1/2” magnets in each one. While not rare earth strong, they are heft little buggers. Maybe I’ll have to order some of the Lee valley ones, they seem much stronger (and cheap!) but I’ll end up paying more in shipping than the magnets I’d buy! Oh well. That’s what I’ll do for the future, BUT, for the two current ones, any thoughts? I can’t do something too rough, as it’ll scratch the fridge pretty bad. -- Ryan -- Maple Grove, MN |
#6 posted 771 days ago |
I love magnets. I get all of my magnets from this guy -- ----- www.KNWoodworking.com ----- -- |
#7 posted 771 days ago |
Rare earth magnets are far stronger than your ceramic type of the same size. -- Close to Ottawa Ontario Canada |
#8 posted 771 days ago |
You might be able to put down a thin film of rubber cement in the areas where the magnets contact. Ugly? Without a doubt. You could probably bore a single new hole & pop a rare earth in there. Ugly? maybe. Good luck! -- My dad and I built a 65 chev pick up.I killed trannys in that thing for some reason-Hog |
#9 posted 771 days ago |
So you would put the washer on the side facing away from the fridge? I’ll have to do some tinkering with the ones I’ve already got. I’m not sure what kind of magnets they actually are. They were small metal disks – but I don’t know what they were made from. Likely not rare earth – it seems companies are very apt to advertise if they were RE. You live and learn…. -- Ryan -- Maple Grove, MN |
#10 posted 771 days ago |
for the future, definitely stronger magnets will solve your problems, With 6 1/2 in magnets in your current project, it must weigh a half pund, and only have a bout a quarter pund pulling force. with the rare earth, you will get double the force from a single magnet the same size and weight as one of your current ones. as far as saving this project, the only thing I can think of is to it over so those screws catch the top of the fridge door, and the magnet just holds it against the door. you arent going to get much more friction against an enamel or stainless door than you are getting with silicone. |
#11 posted 771 days ago |
It might be that if you put a large washer-like magnet on the fridge you might be able to get the bottle opener to stick reliably to that. -- Greg D. -- the price of freedom is tolerance |
#12 posted 771 days ago |
Or combine those last two ideas: build a hanger bracket for each opener (that the screws will catch and hang onto), and use more powerful magnets to hold those to the fridge. -- My broker promised me he would treat my money as if it were his own. Trouble is, he did. |
#13 posted 771 days ago |
For the one’s you’ve already made, you might get two 3/4 dia X 1/4 thick rare earth magnets, stack and stick both to the fridge door and hang the cap screws on the magnets. Bet the opener would stay put then! -- Gene 'The true soldier fights not because he hates what is in front of him, but because he loves what is behind him.' G. K. Chesterton |
#14 posted 771 days ago |
”So you would put the washer on the side facing away from the fridge?” Yes, a bare magnet has waves of flux permeating all around it, a washer (or any ferromagnetic medium) will focus the waves away from it, increasing its strength. -- Close to Ottawa Ontario Canada |
| Forum | Topics |
Woodworking Skill Share
8792 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1532 |
3547 |
15776 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2840 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6158 |
