I want to buy a planer, help!!!
Forum topic by WarpWookie posted 02-15-2018 06:05 PM 493 views 0 times favorited 9 replies Add to Favorites Watch
View WarpWookie's profile
WarpWookie
3 posts in 158 days
02-15-2018 06:05 PM
Topic tags/keywords: planer dewalt delta
Hey Lumberjocks!
I’m in the market for a bench-top planer, looking to spend around $300-$500. The two I’m looking at closely are the Dewalt DW734 and Delta 22-590.
I’ve seen a lot of reviews on the Dewalt and lots of good things, but the delta seems to be a newer to market product that could be good or bad right?
What planer do you use or have used or what might you recommend, or maybe is there a brand in this price range that I’m not currently considering?
Thanks
9 replies so far
View EarlS's profile
EarlS
1125 posts in 2373 days
#1 posted 02-15-2018 06:10 PM
Check out the DW735. A lot of us have it and really like it. It is frequently sold with the stand and in/out feed tables plus an extra set of knives. It might be a bit more expensive than the 734 but you won’t regret it. Also, take a look at LJ reviews on the various planers.
View Loren's profile
10476 posts in 3672 days
#2 posted 02-15-2018 06:18 PM
I had a DW733. I thought it was terrific at
the time. It sniped a bit though. They all do
I think, just to lesser or greater degrees. I would
leave boards about 4-6” longer than I needed
and cut off the sniped portion. Later I built
an infeed/outfeed support thing and that helped
reduce snipe.
View GR8HUNTER's profile
GR8HUNTER
4007 posts in 737 days
#3 posted 02-15-2018 06:25 PM
i have the 22-540 and love it …for a lunch box :<))
View jmartel's profile
jmartel
7954 posts in 2175 days
#4 posted 02-15-2018 06:37 PM
Get the Dewalt. If you can spring for it, the 735 is better than the 734.
View YesHaveSome's profile
YesHaveSome
95 posts in 283 days
#5 posted 02-15-2018 07:47 PM
I have the 735. I got it with an Oneida Mini Gorilla off of Craigslist for $900. Both were very lightly used. It’s my first planer but I have no complaints. It snipes occasionally but getting the tables helped out with that.
-- But where does the meat go?
WarpWookie
3 posts in 158 days
#6 posted 02-15-2018 09:43 PM
Yeah my major concern with the DW735 was the amount of space between the blade head and the rollers being further than the DW734. I was thinking the DW 734 might be better for me because I sometime need to plane down some shorter length pieces of wood. I also heard from review that because of that distance it also has issues with more snipe. Seems like that may not be the case from all these posts, thoughts?
WarpWookie
3 posts in 158 days
#7 posted 02-15-2018 09:45 PM
So here is another question why is the dw735 better than the dw 734 in the above opinions, what does it do different or do better than the dw734
View JohnKaye's profile
JohnKaye
17 posts in 2788 days
#8 posted 02-15-2018 09:50 PM
You can always mount a smaller board on a longer piece of mdf or plywood and plane it that way. Also you can mount and support a warped or wide (12”) board on a substrate and flatten on side through the planer. Then unmount the board and plane the other side. Jointer not needed. DW735 best for this and works great.
View knotscott's profile
knotscott
8056 posts in 3400 days
#9 posted 02-15-2018 11:59 PM
- WarpWookie
“Better” is always subjective, but the 735 has more features…. a chip ejector for one, and I think it might offer multiple speeds. Still, the 734 is a well proven capable tool. I would shy away from anything Delta these days unless I had very compelling information to sway me.
