| Forum topic by 4Doose | posted 771 days ago | 3950 views | 0 times favorited | 18 replies | ![]() |
771 days ago |
Topic tags/keywords: removing twist remove twist twisted twist Hello After letting my fir sit in the garage for most of the winter to dry out and acclimate I fired up the jointer to begin milling. I have a mix of 2×4 and 4×4’s that I am making my work bench out of. The 4×4’s dried well with no cup or twist. The 2×4’s, however, dont seem to have any cup but twisted up to 1/4 across the length. Let me take a moment to disclose that this is the FIRST time I have used the jointer with wood I intend to use for a project. It is set up perfectly according to the owners manual. This is also my first project and am a complete novice to woodworking. Thought you may want to know who you are dealing with ;) The 4×4’s came out perfectly flat and square on 2 sides. The 2×4’s are not proving so easy. Fortunately I stopped on the first board to seek enlightenment from some Jocks. I had assumed that eventually I could mill out the twist with enough passes by stopping each pass when the lumber began to raise up off the cutter then start a new pass and go a little further each time. It seems logical but alas it is not working. I am ending up with what looks like will be a fantastic long bow, all I need is a draw string now. I stopped on the first board as soon as I noticed the board was not getting flat, just deformed. I have looked through several books I have and googled my issue but I am not finding a solution to my problem. The 2×4’s will be glued together to form a 3” thick bench top so any twist is unacceptable. So can anyone educate me on the correct procedure for flattening these twisted 2×4’s? Thank you, -- David, maker of fine sawdust -- |
18 replies so far
#1 posted 771 days ago |
if they are twisted 1/4” i do those by keeping the crown up -- david - only thru kindness can this world be whole . If we don't succeed we run the risk of failure. Dan Quayle |
#2 posted 771 days ago |
Pretty much what David said there. Make short passes on each end multiple times until the cup is almost gone then start face jointing. After it’s flat then take it to the planer. http://www.youtube.com/watch?v=UqVkISnNx0w -- Williamsburg, KY |
#3 posted 771 days ago |
Pine and fir are mostly pretty easy to bend a bit, so while I do recommend Your finished slab may misbehave for awhile due to the stresses in the Jointing on a jointer takes a lot of practice and self-critiquing. The |
#4 posted 771 days ago |
Thanks for the information. While waiting for some replies I went back to the jointer and the piece of wood I already started on. I dont know why the 4×4s turned out so nice but they did. Dead flat end to end and perfectly square on 2 sides. The 2×4 though.. wow. I cant yet tell what I am doing but what ever it is its making the board far worse than ot was when I started. I flipped the board over to the untouched side and scribbled all over it with pencil to see exactly what was getting removed as I passed the wood across the jointer. Interestingly I did see that the opposite high ends were getting planed down, as I wanted. However, as the high spots begin to flatten out the leading edge of the board starts to become thin and about midway down the board it stops touching the cutter and I start making a new long bow again. Its a strange looking piece of wood not with the ends about 1” each and the center about 1.25” So as Loren mentions above I can see that a lot of scrap wood will become long bows before I know what I am doing. Until then the workbench wood will be set aside and a lot of scrap pallet wood will be coming home from the work dumpster to practice on. -- David, maker of fine sawdust -- |
#5 posted 771 days ago |
Get a metal detector for that pallet wood. I chipped my jointer knives on a hidden nail in some pallet wood. |
#6 posted 771 days ago |
“Get a metal detector for that pallet wood. I chipped my jointer knives on a hidden nail in some pallet wood.” Just so happens I have one. I will indeed, thanks for the tip. -- David, maker of fine sawdust -- |
#7 posted 771 days ago |
Put the concave side down and go the full length of the board until the jointer cuts the full length then it should be flat and straight. Then take it to a planer or a saw and make the opposite side parallel. Don’t apply pressure to the board or you will defeat the purpose of the exercise. |
#8 posted 771 days ago |
The first thing you can do to ,greatly ,reduce the amount of ,crook or bow ,is to cross cut ,the stock, if you have an 8 foot length ,and you only need a ,2, 3, 4, 5 or 6 foot length,cross cut the stock, closer to ,the length you need,but leave extra. Here is a Video http://www.youtube.com/watch?v=qqqa6W8m6Y8 -- E J ------- Always Keep a Firm Grip on Your Tool |
#9 posted 771 days ago |
Here’s another Video—http://www.youtube.com/watch?v=UqVkISnNx0w -- E J ------- Always Keep a Firm Grip on Your Tool |
#10 posted 771 days ago |
to second Grandpa, i believe you problem is coming from the application of pressure on the board as it moves across the jointer. the 4×4 is much harder to deflect than a 2×4, which is why you dont see the problem there. you want to keep pressure as light as possible – just the weight of the board itself if you can do that. |
#11 posted 771 days ago |
As soon as you get them home, wrap them in the stretchy plastic wrap (used in packaging). Leave just the end grain exposed. When you are ready to use them unwrap them and use them right away. I’ve used this procedure for years and I always have straight 2×4’s when I need them. -- Don, Diamond Lake Custom Woodworks - http://www.dlwoodworks.com - "If you make something idiot proof, all they do is make a better idiot" |
#12 posted 771 days ago |
I have to remember I am not machining steel anymore. I believe I am putting excessive pressure on the board as many of you mention. I will watch the videos later and when I get home from work tonight I will try out a feather touch and see what happens. Thank you all for the insight. -- David, maker of fine sawdust -- |
#13 posted 771 days ago |
2×4’s are usually cut from less quality parts of the log, sometimes even from poor quality or very small logs, as they are the smallest cuts most mills make for lumber; bigger wood is more likely from a more stable part of the log. The best wood is reserved for bigger pieces as they sell for more money. 4×4’s are much more stable due to their mass. There is a lot to be said for studying the growth lines in a board in reference to how it will move when drying, you may want to snoop around a book or three as the info is good to have if you plan on using green lumber to work with. I have found kiln dried 2×4’s at my local HD store at the same price as non kiln dried, they may be a better option for this type of project. I guess none of this is any help today, but hopefully may help you in the future. Lastly, you may want to consider slicing a 4×4 down to your 3” for that top rather than relying on a glue up. -- Power tools put us ahead of the monkeys |
#14 posted 771 days ago |
Maybe change your plans and go for a butcher-block style top rather than one where each strip runs the entire length of the bench. As bubinga suggested, cut the 2×4s into 3’ or 2’ lengths and they will be easier to joint and you will get better yield. The downside is that it will take several to make up the desired length of your benchtop. With a 3” thick top – cripes that is thick – I don’t think that will be a problem so long as you stagger the joints. -- Greg D. -- the price of freedom is tolerance |
#15 posted 771 days ago |
very good idea Greg, something we can all keep in mind. |
| Forum | Topics |
Woodworking Skill Share
8791 |
Woodturning
221 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1530 |
3547 |
15769 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2838 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6157 |
