Formica laminate bubble
Forum topic by loogilineloom posted 02-15-2018 08:14 AM 326 views 0 times favorited 1 reply Add to Favorites Watch
View loogilineloom's profile
loogilineloom
8 posts in 3004 days
02-15-2018 08:14 AM
Topic tags/keywords: formica metal doors glue laminate question
Hi!
I´m trying to glue formica laminate to metal doors (zinc metal), but after some time (about week) some laminate will develope bubbles, but most wont. Glue i use is SIMSON MSR BC, so i wonder if any of you have any ideas what is making the bubbles, could it be cold (the metal is shrinking, and laminate wont)? Dents in door surface? Frankly i think it could be all of reasons or none of reasons. Previously i used liquid PUR, but the outcome was far worse.
PS. sorry for my grammar, english is not my native language :)
-- if you do not have the time to do things correctly then you must have the time to do things again
1 reply so far
View Kelly's profile
Kelly
2102 posts in 3117 days
#1 posted 03-04-2018 04:03 PM
Quick question: How hot does the door get?
When I laminated large surfaces, I had a couple trouble spots that broke loose. I heated the area with my hot air gun, laid weight on it and let it sit for a few hours. After that, the area was good as gold again. As such, if you had significant heat on a metal door, it could delaminate with contact type cements.
