TS cutting on when i pull back the miter gauge
« back to Joinery forum
Forum topic by stripit posted 02-14-2018 10:30 PM 873 views 0 times favorited 9 replies Add to Favorites Watch
View stripit's profile
stripit
25 posts in 2248 days
02-14-2018 10:30 PM
Topic tags/keywords: jig question
Hi. Can anyone tell me why my Ts (delta unisaw) cuts when I pull the sled (incra express) back. This causing a gap in the mite joint at one end. I have checkedd the blade for 90, and the miter for 45 and both are good. What am I missing.
Thank for any heelp Joel
9 replies so far
View fivecodys's profile
fivecodys
1228 posts in 1841 days
#1 posted 02-14-2018 11:01 PM
Any slop in the miter slot? Maybe the rail is moving around in the slot when you pull it backwards?
-- I always knew I would grow old, But I expected it to take longer!
View eflanders's profile
eflanders
318 posts in 2055 days
#2 posted 02-14-2018 11:02 PM
Sounds to me like an alignment issue. Things to check are: 1). My Inca jig came with plastic washers to maintain a good fit into the miter gauge slot. Is your gauge showing any side to side slop in the miter gauge slot? 2). Have you checked the blade for alignment to the miter gauge slot? A dial caliper is usually used for this but you can get very close with an accurate tape or by simply clamping a board to the miter guage. 3). Is your miter guage square to the table? This is the very first step in setting up your miter gauge. 4). Does your blade have some warp or wobble to it? This is somewhat rare but it does happen. Try another blade and see if it does the same thing. Good luck!
runswithscissors
2897 posts in 2230 days
#3 posted 02-15-2018 10:43 PM
I would prefer not to pull the wood back past the blade until the saw has stopped. There must be some slop somewhere allowing movement, as suggested above.
View Tennessee's profile
Tennessee
2893 posts in 2719 days
#4 posted 02-15-2018 10:57 PM
Mine did that. Same thing. My miter slots were nice and tight, and my segments I was cutting were fine, but that little bit of cut coming back bothered me.
SOLUTION: Turned out that my blade has just a hair of wobble in the blade. Maybe 2-3 thousandths. Not a completely flat blade. It is an Irwin that came out of the package like that. I plan on changing it soon.
stripit
#5 posted 02-26-2018 01:11 AM
Hi thanks to all those who took the time to write.
I checked everything, and found that the sled was a little loose in the table slot, and the blade is a littleout (
another Irwin). The real problem was that the long frame pieces were wrapped. I joined and planed them, but could not take enough off to get them flat. Guess I’ll cut them in half and make a smaller frame.
Thanks again for the advice.
Joel
View waho6o9's profile
waho6o9
8525 posts in 2782 days
#6 posted 02-26-2018 01:39 AM
Bessey hold downs may come in handy for a sacrificial sled.
View Alex Lane's profile
Alex Lane
541 posts in 4095 days
#7 posted 02-26-2018 01:43 AM
I’ve also had the workpiece inadvertently slide out of position against the miter gauge face, especially when the blade begins to lose its sharpness or if the blade is set at an angle. A piece of fine grit sandpaper on the miter gauge face can help prevent that (either adhesive sandpaper or adhered with double face tape). Even with a wobbly blade, it will only cut to it’s maximum wobble point. Once it has removed wood, the only way it can remove more wood on the way back past the blade is if the wood moved closer to the blade. Likely the change from pushing the wood to now pulling the wood changed the direction of force against the sides of the miter slot and allowed the wood to move slightly closer to the blade. Or the wood moved out of position on the miter gauge as mentioned.
-- Lane Custom Guitars and Basses
View Woodknack's profile
Woodknack
12431 posts in 2585 days
#8 posted 02-26-2018 02:36 AM
Best practice is don’t pull the wood back through the blade, true for both table and miter saws. (on a miter saw it’s the opposite actually, raising the blade through the wood) You should make your cut then pull the piece away from the blade.
View splintergroup's profile
splintergroup
2436 posts in 1427 days
#9 posted 02-26-2018 04:30 PM
I have a Unisaw/Incra combination and my experience shows problems creep in due to the general over-width of Delta miter slots and the undersized nature of aftermarket miter bars so they fit saws with undersized slots.
This adds up to a sloppy bar/slot fit that even the adjustment washers on my Incra could not remove.
I ended up modifying the miter bar to tighten up the fit.
