Stanley power plane knives
Forum topic by shipwright posted 02-14-2018 06:14 PM 460 views 0 times favorited 9 replies Add to Favorites Watch
View shipwright's profile
shipwright
8031 posts in 2883 days
02-14-2018 06:14 PM
Anybody have a source for knives for this? It is a model # FME 360
Thanks.
9 replies so far
View Rich's profile
Rich
3350 posts in 675 days
#1 posted 02-14-2018 06:39 PM
It doesn’t appear to be a mainstream USA product. Most of the links go to overseas web sites. Unless the blades have some unique shape, you can likely find blades that fit just based on length, width and thickness. Isn’t there a LJ who runs a cutter supply? Holbren?
View Dutchy's profile
Dutchy
3037 posts in 2254 days
#2 posted 02-14-2018 06:44 PM
Is it a re-sharpenable HSS or a reversel TC blade? Reverseble blades are 5.5 mm width and mostly 75 or 82 mm long.
-- https://dutchypatterns.com/
View RobHannon's profile
RobHannon
143 posts in 616 days
#3 posted 02-14-2018 06:59 PM
Looks like that one takes 3 1/4” or 82mm double sided carbide blades. Bunch of planers take the same style blade. https://www.amazon.com/Bosch-PA1202-Woodrazor-Tungsten-Carbide/dp/B00020J1Q2 looks to be the same style.
View DocSavage45's profile
DocSavage45
8657 posts in 2928 days
#4 posted 02-14-2018 07:45 PM
You might check James Hamilton Stumpy Nubbs site. He has a sponsor that makes cutters. Goood hunting!
-- Cau Haus Designs, Thomas J. Tieffenbacher
View Jim Jakosh's profile
Jim Jakosh
20927 posts in 3191 days
#5 posted 02-14-2018 07:58 PM
Check out these guys:
https://mywoodcutters.com/index.php?_route_=Replacement_Knives_for_Planers_and_Jointers&gclid=Cj0KCQiA2Y_UBRCGARIsALglqQ21SrWOawrtjfmkhRHfi9jphDeeNa9M9kKUF2D3IF_vKHVL0MIEwM8aAtAiEALw_wcB
View Schwieb's profile
Schwieb
1862 posts in 3547 days
#6 posted 02-14-2018 08:55 PM
Paul, check with https://www.ereplacementparts.com/?osCsid=pbp2o5mnir7244n8mjd55iikl6 I’ve had good luck with finding parts and knives through them
-- Dr. Ken, Florida - Durch harte arbeit werden Träume wahr.
View Lazyman's profile
Lazyman
2288 posts in 1473 days
#7 posted 02-14-2018 09:50 PM
Maybe these(?): https://www.amazon.com/dp/B01N9NLZ6C/ref=psdc_552328_t2_B01MTKQVI5
It has the dimensions so you can check against the ones in yours.
Sure looks like it is identical in design to the Porter Cable PC60THPK. Looks similar to the current Stanley Fatmax 750W so perhaps the blades are interchangeable on most 3.25” planers?
shipwright
#8 posted 02-15-2018 12:14 AM
Not for me. It’s for a friend. He took the planer back and I’m waiting for the dimensions.
The knives in the machine are not double sided but I’m betting they will be the generic ones.
Thanks for the responses. I will stay in touch.
shipwright
#9 posted 02-15-2018 01:09 AM
Looks like the 3 1/4” ones posted by a couple of you are likely the ones so we’re ordering a set. All he has to lose is $11 but I’m betting they fit.
Thanks to you all.
