Jet Jointer problem
Forum topic by MOwood posted 04-09-2011 09:39 PM 2000 views 0 times favorited 6 replies Add to Favorites Watch
View MOwood's profile
MOwood
36 posts in 3809 days
04-09-2011 09:39 PM
Topic tags/keywords: jointer problem troubleshooting
Well I got a really good deal on a used Jet JJ-6CS jointer that I found on Craigslist. I guess the old saying that a good thing is too good to be true still applies. Whenever I am edge jointing a piece of Oak the machine shuts off in the middle of the cut. I am thinking this might be the switch going bad or maybe it has a thermal overload of some sort? Anyone had this problem before or have any suggestions on how to fix it? I know this is a great machine and must surely just be a minor issue causing a major problem. Any ideas would be appreciated.
Thanks,
Greg
View NBeener's profile
NBeener
4816 posts in 3201 days
#1 posted 04-09-2011 09:44 PM
There’s a troubleshooting section in the manual that actually DOES do a good job of pointing out the likely issues.
I’d guess switch, but … let us know what you find out, huh ?
-- -- Neil
View syenefarmer's profile
syenefarmer
492 posts in 3107 days
#2 posted 04-09-2011 09:47 PM
I too would guess your problem is with the switch.
View Lee Barker's profile
Lee Barker
2170 posts in 2877 days
#3 posted 04-10-2011 02:50 AM
After it shuts off, how do you get it back on?
The plug is a suspect as well as the switch and the associated connections.
Also the wire connections in the little j-box on the motor. Those have wirenuts often; that’s worth checking.
Or perhaps it has an oak allergy. Try other species that aren’t blooming right now. : )
Kindly,
View Camper's profile
Camper
232 posts in 2883 days
#4 posted 04-10-2011 04:42 AM
Does it shut-off when you are not applying any load to the motor e.g. not cutting something? If not, then I would suspect the motor rather than the switch. Does it happen more often during heavier vs. lighter cuts?
-- Tampa-FL
MOwood
#5 posted 04-10-2011 05:26 AM
Thanks for all the responses. I checked my manual for a troubleshooting section but for some reason it didn’t have one, I also did a brief search online but came up empty. It only shuts off when under heavy load. To restart it I just hit the On switch again. I did make a trip up to Grizzly and asked for their suggestions, they thought it sounded like it could be the capacitor on the motor. I may start with replacing the capacitor, surely that will be cheaper than a switch. Lee it highly could be an oak allergy, those darn allergies seem to shut me down too.
MOwood
#6 posted 04-12-2011 05:54 AM
Well the folks at Grizzly do know what they are talking about. I made it up there today and got a new capacitor and now it works great.
