Rigid flip top work stand
Forum topic by Wood_smith posted 04-09-2011 05:57 PM 3039 views 0 times favorited 4 replies Add to Favorites Watch
View Wood_smith's profile
Wood_smith
260 posts in 3201 days
04-09-2011 05:57 PM
Has anyone used one of these? They look pretty neat, but I don’t know if they would work as good as a set of roller balls on a board in my Workmate.
http://www.ridgid.com/Tools/AC9934-Work-Support/EN/index.htm
-- Lloyd Kerry; creator of the Kerry-All Pouch, http://www.kerrywoodworking.com
View Hoakie's profile
Hoakie
306 posts in 4211 days
#1 posted 04-09-2011 06:06 PM
I have one and am pleased with it. I mainly use it for supporting longer sheets that extend off the bench while knocking down them down to more manageable pieces with a circular saw or my jig saw. I have used it for infeed/outfeed support and it works just fine. I’m guessing the ball-type would allow the material to move more freely but I haven’t had an issue in my limited experience.
-- John H. [To invent, you need a good imagination and a pile of junk. ~Edison]
View JasonWagner's profile
JasonWagner
527 posts in 3355 days
#2 posted 04-09-2011 06:07 PM
Yep, got two of them. I use them for left side support and for outfeed support. The slanted top allows for longer wood to flex downward on outfeed but catch and raise the piece on the stand (if that makes sense). You can adjust the top to stay flat as well.
-- some day I hope to have enough clamps to need a clamp cart!
View C_PLUS_Woodworker's profile
C_PLUS_Woodworker
601 posts in 3083 days
#3 posted 04-09-2011 06:15 PM
I have one exactly like that made by B & D that is 20-30 years old…......and I like it a lot.
Use it the same way Jason and Hoakie use theirs.
I like it better than a 4-roller stand I have.
Hit it with a little wax before you use it and stock slides much better.
View Loren's profile
10477 posts in 3823 days
#4 posted 04-09-2011 06:25 PM
I have a couple of those. They were off the market for awhile.
The rubber feet fall off and fall apart. Other than that, they are
useful for quick work supports and for saw outfeeds.
I like them better than roller stands too.
