Flea market find and a question
Forum topic by hairy posted 04-09-2011 04:30 PM 1994 views 0 times favorited 8 replies Add to Favorites Watch
View hairy's profile
hairy
2783 posts in 3766 days
04-09-2011 04:30 PM
Stanley No. 12 veneer scraper
I could not just walk past. But, it needs a blade. I suspect I will pay more for the blade than the tool.
Some say to make a blade from an old saw, the metal will have the thickness to flex properly. Others ( replacement blade sellers) say a thicker blade will cut better because it won’t flex.
All help is appreciated. Thanks!
-- My reality check bounced...
8 replies so far
Beginningwoodworker
13345 posts in 3906 days
#1 posted 04-09-2011 05:10 PM
Nice find, I had one of those but I sold it. You can buy a Hock no 12 replacement blade for it.
View drewnahant's profile
drewnahant
222 posts in 3322 days
#2 posted 04-09-2011 05:46 PM
I have that exact scraper plane, in about the same condition, I could swear you took the picture from me. Mine didnt have a blade either, so I tried using different blades, and I agree that you need the thick blade. I started by using a regular card scraper ( a nice thin LN), which is a bit narrow, but it was a good test, it was horrible! I then tried a stanley card scraper, which I had to cut down to size, about 4 times as thick, better, but still not working properly. I borrowed a friend’s #12 scraper with the thick blade and tried that blade in it, worked great. I still havent spent the money on a real blade, but I can tell you that for this tool to work properly, it is the only way to go.
View Loren's profile
10477 posts in 3881 days
#3 posted 04-09-2011 05:56 PM
A thick card scraper will work nicely. You bevel the edge to 45 degrees
and raise a burr on the one edge.
hairy
#4 posted 04-09-2011 06:12 PM
Thanks! The burr is another thing I have found conflicting info about.
#5 posted 04-09-2011 06:28 PM
Maybe 30 degrees is fine too. It’s not super critical actually. You’ll
want to use a card scraper for your final passes anyway, so these
scraper planes are really for scraping a whole board quickly.
hairy
#6 posted 04-09-2011 06:40 PM
I think it was a thin blade needs a burr, a thick blade is sharpened like a plane blade.
The cool thing about this tool is that the angle is adjustable.
#7 posted 04-09-2011 06:57 PM
I don’t always bother with the burr. You can do it either way.
View hObOmOnk's profile
hObOmOnk
1381 posts in 4361 days
#8 posted 04-09-2011 09:29 PM
Sharpening info from Lee Valley.
-- 温故知新
