Talon chuck with insert (1 1/4 x 8) cross LH/RH threaded question
« back to Woodturning forum
Forum topic by 9x9 posted 02-13-2018 04:08 PM 400 views 0 times favorited 4 replies Add to Favorites Watch
View 9x9's profile
9x9
97 posts in 1478 days
02-13-2018 04:08 PM
Looking at getting the Oneway Talon chuck with insert (1 1/4×8) cross LH/RH threaded. Just wondering what y’all think about the thread strength (being threaded both ways) and how it will hold as far as any run out. This is for Robust Scout lathe with 14” swing over ways inboard 21” swing outboard. Lathe has spindle threaded (1 1/4×8) RH inboard and (1 1/4×8) LH outboard. Robust face plate for this lathe is threaded this way (cross LH/RH).
-- Youngsville, LA
View GR8HUNTER's profile
GR8HUNTER
5379 posts in 950 days
#1 posted 02-13-2018 04:12 PM
WHAT ?? :<))
View LeeMills's profile
LeeMills
629 posts in 1539 days
#2 posted 02-13-2018 07:51 PM
Nova makes an insert which is LH/RH also but I haven’t used one.
I would think they would hold up fine. All of my chucks are sorta wobbly threading them on until the end of the insert seats against the headstock. I don’t think the treads do much as the transfer of power is at the end. Maybe we have some engineers who have had experience with them.
View HapHazzard's profile
HapHazzard
116 posts in 1106 days
#3 posted 02-15-2018 02:30 AM
At the risk of stating the obvious, it all comes down to precision and choice of material. 50% cut cross-threads in 1.25-ish 1018 steel won’t last too long. 75% or better in 1.250” 4340, carburized, now you’re talking.
-- Unix programmers never die; they just > /dev/null
View Wildwood's profile
Wildwood
2527 posts in 2372 days
#4 posted 02-15-2018 02:11 PM
Doubt if Oneway makes an insert 1 1/4” x 8 TPI RH/LH thread. Could not find one at thier site. They may make one special for you but not sure worth the trouble or expense. 99% of your turning will be over the ways.
Would not have any idea about run out. Just the cost of Robust accessories needed to turn out board would have me making something else work.
Might make more sense to get a Oneway LH threaded face plate. They do make have plates in different sizes(3,4, 6, & 8”) to fit your lathe with RH/LH threads.
If not mistaken picture of outbaord tuning using a faceplate.
http://www.turnrobust.com/lathe-overview/scout/
I would rather have just left hand threads versus combo RH/LH.
-- Bill
