Resawing dry wood without causing stress movements
Forum topic by TopamaxSurvivor posted 802 days ago 1597 views 0 times favorited 24 replies Add to Favorites Watch
TopamaxSurvivor
13179 posts in 1874 days
802 days ago
Topic tags/keywords: resaw dry wood stress movement cup warp
I have followed a lot of issues here on LJ the last couple of years where fellow JLs have experienced various stress changes in wood they have sawn. I have a piece of dry 9/4×9 x 28 inch blackline spalted maple I want to resaw on of these days. I am thinking the best time to saw it will be in the hot, dry days of the August summer. I believe it was air dried in western Oregon. I am also thinking I will sand a 1/16 off the side opposite the saw cut. I am hoping this should receive the board of the propensity to cup, warp bow, curl or otherwise decide to change shape. Any comments, suggestions or criticism of the plan? Better ideas??
-- "some old things are lovely, warm still with life ... of the forgotten men who made them." - D.H. Lawrence
24 replies so far
12172 posts in 1539 days
#1 posted 802 days ago
spell relieve
wish i knew more about the milling and drying end of things
done allot of felling
and allot of using
but not much knowledge about the sawmill side of wood
only one way to find out
keep us posted
always ready to learn something
the proof is in the
blackline spalted maple pudding
View ScottN's profile
ScottN
259 posts in 877 days
#2 posted 802 days ago
All stressed wood is a result from the moisture in the wood, it will absorb or desorb moisture until it is in equilibrium with its surroundings. The biggest factor is in the drying process. When wood is kihln dried, they’ll dry the wood down
and shrink the cells in the wood and the condition the wood by slowly bring the moisture content back into the wood. Each wood species is different and needs to be done so accordingly. And if its not done correctly and rushed through the process you’ll get case hardening…which is “stressed wood”.
The same thing applies to your wood shops. Most woodshops and millworks keep there shops around 40-45% humidity to prevent adding stress to the wood.I keep my shop between 40-50%. So if you keep your windows open or exhaust your dust collector outside I don’t see how you you can control the humidity levels in your shop.If you don’t control the humidity level you’ll end up with more bowed, cupped and internal stressed boards…your call.
I was debating if I should post this or not. But I think its important.
-- New Auburn,WI
ScottN
#3 posted 802 days ago
I was searching for a video to further explain what I was getting at. http://youtu.be/HQGjDHtN3MQ
-- New Auburn,WI
View NBeener's profile
NBeener
4805 posts in 1372 days
#4 posted 802 days ago
ScottN:
Darn.
My shop DOES stay at between 41% and 43% RH.
Meaning …. I have to find yet another excuse for my crappy woodworking ;-)
Good info. Thanks !
-- -- Neil
View Bob Kollman's profile
Bob Kollman
1779 posts in 1389 days
#5 posted 802 days ago
I work with exotic plastics, basicly we anneal the plastic and then machine it.
in dealing with movement and stress the best approach is to cut rough, let
the material spring. With wood it is the same. You can also insure a good out come
by doing several rough operations by making several rough cuts pulling the twisting
and cupping out as you go along. We use a lot of double sided tape turning on the
lathe. This way we can remove the high points with out puting any external force on
the material, after out first side is flat and stress free, it’s just a matter of maching
the second side. My biggest problem is my jointer has only 6” of width, but I can
rely on the 6” and less boards to be dead flat. The big issue is removing the high
without stressing the material i.e. the rollers on your planer usually put to much
external force on the high spots…..Basicly it’s a matter of building jigs, using hand tools,
to think your way thru the stressed material problem…..I think i had to much coffee
already!!!! Blah blah blah…LOL
-- Bob Kenosha Wi.
View stefang's profile (online now)
stefang
9728 posts in 1532 days
#6 posted 802 days ago
Scott knows what he is talking about. I live in a climate with high humidity as you yourself do. This climate is pretty ideal for woodworking as opposed to other areas which are much less humid and where there are big differences between summer and winter humidity. It’s the differences that get you. However, I don’t obsess on this. I just try to use my materials before they begin to warp, and I rarely have any warping problems once they are incorporated into my projects. So I guess I’m saying ignorance is bliss, but only because you live in a wet area like myself. I know my advice sounds a little stupid, but if you build with the warp problem in mind, you shouldn’t have a lot of problems. Ok now I am in for it. Shoot away folks!
-- Mike, American in Norway
View tenontim's profile
tenontim
2130 posts in 1942 days
#7 posted 802 days ago
I will usually mill the board to a thickness more than I need. Let them acclimate to the shop for about a week, so I can see what they’re going to do, then do the final milling to size. This will head off many of the problems.
-- Tim-- http://www.tmuli.com
TopamaxSurvivor
#8 posted 802 days ago
Thanks guys, The board is flat now without any obvious signs of trouble. i have had it for about 6 months. i guess my concern is finding trouble a day or two after I resaw it. My thought was to expose new surface on both sides to reduce the risk of loss of equilibrium. ???? ;-)) Who knows until I do it eh? The shop is a garage with a double door that is opened frequently. Humidity control is out of the question. But, we never go to less than 30% and are usually in the 50 to 70% range. I’m not 10 % what I will do with it, but I have some ideas.
I’m afraid to resaw it thinner than an inch. Do you think I will be better off keeping it thicker than 3/8 to 1/2 inch?
TopamaxSurvivor
#9 posted 802 days ago
Guess I’m trying to be proactive rather than sorry ;-)
View Jack_T's profile
Jack_T
620 posts in 1229 days
#10 posted 802 days ago
You could cut it into veneers and really stretch the spalt.
-- Jack T, John 3:16 "For God so loved the world that he gave his only Son, so that everyone who believes in him might not perish but might have eternal life."
View rance's profile
rance
3865 posts in 1358 days
#11 posted 802 days ago
I mostly agree with tennontim. I might only extend the acclimation period. Imagine your board as a big sponge. The outer layers are drier than the inner layers because the inner layers are insulated by the outer layers. When you cut down the middle, you are exposing those moist inner layers. When they dry, they will likely affect the board because it is unbalanced.
If you resaw a board into thirds, then let the pieces dry, the middle third is mostly likely to remain straight since you have exposed equal parts on two opposite surfaces. The outer two boards are not quite as likely to remain straight since they now have a dry side and a moist side. They are unbalanced, moisture-wise, and as they reach equilibrium, they are likely to move.
TopamaxSurvivor
#12 posted 802 days ago
That is why I was thinking of doing an aggressive sanding on the out side before the resaw. Will that make much difference or just stir up a lot of dust?
View John Ormsby's profile
John Ormsby
1238 posts in 1935 days
#13 posted 802 days ago
I would suggest you also plan your project to re-saw the spalted wood and work it and glue it in place the same day. This will insure that it stays straight. I have never had a problem with a board once it is in place. Most woods that tend to warp or move should be worked at once and secured. You will have much more movement if the processed board is left to “acclimate”. Just my 2 cents worth.
-- Oldworld, Fair Oaks, Ca
rance
#14 posted 802 days ago
Topo, 1/16” off one side and 1/2” or more on the other? Only doing it will really tell. I’m just telling you you have a better chance with equal on both sides. Sorry, I’m just not that much of a wood whisperer.
Bob Kollman
#15 posted 802 days ago
Resaw….be happy!!!! :) Good luck, and may the warp be without you!!!!
-- Bob Kenosha Wi.
