Jointech Smartfence inserts
Forum topic by willyp posted 802 days ago 1533 views 0 times favorited 8 replies Add to Favorites Watch
View willyp's profile
willyp
2 posts in 803 days
802 days ago
I purchased a Jointech Smart fence system over 2 years ago. When delivered I only received one Smart fence insert. After repeated attempts to contact Jointech over the last two years for the extra inserts that I did not receive with my order I have given up trying to get them Jointech.
I have decided to see if I can have them manufactured. I was wondering if anyone else out there is in the same situation as I am in and needs more Smart fence inserts. I have been told that the larger the quantity I purchase the lower the cost per unit would be. I am currently working on the CAD drawing to submit to several vendors to get a cost estimate on the cost to make the inserts so I do not have any prices. I am trying to find out if there is any interest so I can give the vendor the quantity I would like manufactured. So if anyone is interested in the inserts or knows of someone who is response to this post.
Thanks
Willyp
8 replies so far
View Gene Howe's profile
Gene Howe
3217 posts in 1626 days
#1 posted 802 days ago
Willy,
I could use 6, or more.
I’ll bet we could have them cut by someone with a CNC. They wouldn’t have to be semi hollow. A stable wood would work for me in AZ. Don’t know about places with higher humidity, though.
willyp
2 posts in 803 days
#2 posted 802 days ago
Gene,
I will keep you informed. I have the drawing done. I know of a couple of shops that I believe can make them from delrin. The one block I have I believe is made out of a 3/4 inch block of delrin, it is machined not molded There is no machining of the block except for the round parts that fit into the fence. Delrin is very moisture resistance. If you know of any other sites I can get my message out on let me know. I would like to get as many produced to reduce cost. I have attached a picture of the insert that I have.
Willy
View jepedo's profile
jepedo
1 post in 229 days
#3 posted 229 days ago
Willy,
Did you ever make the profile inserts? If so i would be interested in buying a few?
thanks
v/r
jepedo
View ducksoup's profile
ducksoup
1 post in 239 days
#4 posted 222 days ago
LumberJock newbe here. 35+ years in woodworking. i bought my Jointech fence several years ago and built my router table specifically for it. I might be interested also but I’m concerned about a solid delrin one though. The originals were set up with that thin center panel that you could feed a spinning router bit through it to get the perfect fit. I’m not sure I’d want to do that with 3/4” solid delrin? I suppose they could be made so the center part is hollowed out leaving about 1/8” or I could probably do it on my buddys milling machine too. Let me know what you find out.
Tom
View DDwight's profile
DDwight
2 posts in 169 days
#5 posted 169 days ago
I bought my jointech over 10 years ago.
I cannot get any response from Jointech.
I need the insert scale that goes into the sawtrain arm. Can’t find one anywhere.
Any ideas?
DDwight
Gene Howe
#6 posted 169 days ago
DDwight,
Are you referring to the rule/tape?
DDwight
2 posts in 169 days
#7 posted 169 days ago
Yes,the rule tape.
View rustynails's profile
rustynails
362 posts in 727 days
#8 posted 169 days ago
FYI… Jointech has been closed for some time now …
